misfiring megane fidji 2002 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 24th November 2013   #1
damienfidji
damienfidji is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
hello
My megane fidji 1.6 2002 has developed a misfire.
I have tested the coils by pulling them out while engine running and seems that cylinder 2 isnt working as doesn't effect the running of the engine while the others do. I put number 2 coil into cylinder 1 but it fires fine and coil 1 in cylinder 2 doesnt fire now.
So i think the coils are working fine.
So put new spark plugs in but still not firing on cylinder 2.
Any ideas whats happening as i belive i have ruled out the coils and spartk plugs.
Any help would be great
many thanks damien
damienfidji is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by damienfidji
misfiring megane fidji 2002 Engines damienfidji 11 2154 24th November 2013 03:59 PM
Sponsored Links
Advertisement
Old 24th November 2013   #2
lancs dave
lancs dave is
struggling to get in gear
Platinum member
Technical Supremo
lancs dave's Avatar
Nominated 13 Times in 26 Posts
Nominated TOTW/F/M Award(s): 12
Re: misfiring megane fidji 2002
Have you checked the wiring to the injector.
Is the spark plug getting wet after it's been running.
Might well be worth checking the compressions.
Currently in lancs dave's garage:
Less rubbish now I've been to the tip.
lancs dave is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to lancs dave For This Useful Post:
damienfidji (27th November 2013)
Old 27th November 2013   #3
damienfidji
damienfidji is
has no status.
Junior Member
Threadstarter
hi thanks for the reply.
Wires for the injectors are all ok, yes the plugs are wet.
Done compression test and there is no compression on the cylinder .
So it looking like its a valve.
Many thanks for help
Old 28th November 2013   #4
mickeybo
mickeybo is
has no status.
Platinum member
Nominated 2 Times in 10 Posts
Nominated TOTW/F/M Award(s): 6
It would be adviseable to check on this faulty cylinder for a collapsed hydraulic tappet Before jumping to conclusions
Currently in mickeybo's garage:
1996 Renault Clio 1.9 Diesel.
mickeybo is online now   Reply With Quote Quick reply to this message
Old 1st December 2013   #5
damienfidji
damienfidji is
has no status.
Junior Member
Threadstarter
Thanks for the advice!
It seems cheaper to put a new engine in and comes with 3 months warranty, however i will be taking the engine apart to find out what the problem was.
Been told by my mates dad who is a Renault mechanic that even if i change the valves and tappets its liable to of put ware on the engine and likely to happen again.
Does anybody know why there are so many of these engines available second hand at about 60-70k?
My engine had only covered 62k with full service history, whats the deal with these 1600s seems weird that they all seem to go wrong about the same mileage.
What are the chances that the new engine will go wrong?
Thanks in advance
Reply
Tags
fidji, megane, misfiring
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
