Renault Megane 1 - Drive Shaft Problems - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Steering and Suspension
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Reply
Thread Tools Display Modes
Old 22nd May 2007   #1
mull-megane
mull-megane is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
a couple of weeks ago my o/s drive shaft sheared the roller bearings on the gearbox side anp popped out of place. so bought a new end and fitted it got 1 mile out the road and the same thing happend again. someone said there should be a locating pin to hold it in place, there wasent one when i first took it out. got a new end but not fitting it till can find out whats wrong. the cars a 98 renault megane coupe
Currently in mull-megane's garage:
renault megane coupe 98 model.
mull-megane is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by mull-megane
Renault Megane 1 - Drive Shaft Problems Steering and Suspension 5th wheel 5 3728 22nd May 2007 08:58 PM
megane coupe wont start Engines alex21 1 957 12th January 2007 08:19 PM
Sponsored Links
Advertisement
Old 11th July 2007   #2
clunk.stp
clunk.stp is
has no status.
Diamond member
If it is coming out at the gearbox end then there should be a hole drilled through the shaft which must be aligned to another hole on the gearbox output shaft. Once together a roll pin should then be knocked through the hole to keep the shafgt in place. If it is the other end then there should be either a circlip in the cv joint or on the end of the driveshaft.
Currently in clunk.stp's garage:
VeeDub Breakdown Van
clunk.stp is offline   Reply With Quote Quick reply to this message
Old 20th July 2007   #3
leebo
leebo is
has no status.
Member
leebo's Avatar
driveshaft nightmare
hello mate iv got a 1996 megane coupe 2l 16v and im having the same problem even with a roll pin in place. iv got the renault dialog program and it says that u can fit a spring and cup instead of the roll pin but iv phoned the renault dealer and thay havent heared of it before so im going to pop in and show them the diagram i printed of. pls find diagram enclosed for yourself.
Currently in leebo's garage:
1996 Renault Megane RXE16v
leebo is offline   Reply With Quote Quick reply to this message
Old 20th July 2007   #4
selwonk
selwonk is
has no status.
Edit
Posts: n/a
Your attachment has been deleted. Reproduction of copyrighted material is expressly forbidden:
Quote:
Originally Posted by Rules
You should also remember that RenaultForums does not under any circumstances allow the reproduction of copyrighted material. This includes, but is not restricted to:
a) PDF documents such as Dialogys files
b) Screen prints from commercial software
c) Information from copyrighted pages on other web sites
d) Pirated software
Old 20th July 2007   #5
leebo
leebo is
has no status.
Member
leebo's Avatar
ok fare does but i thought we were here to help one n other,
Reply
Tags
drive, megane, problems, renault, shaft
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
