Renault Laguna II - Dashboard diagnostic - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum Problem Solving Ask the Experts Electronics
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 28th May 2007   #1
bobford100
bobford100 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Not sure if this has been reported before, but I have found a way to test the functions of the Laguna dashboard.
Hold down the computer display change button (ADAC?), on the right steering stalk and then insert the keycard.
This will make all of the characters on the LCD display come on as well as cycle all of the gauges from min to max. This I imagine will show whether the gauge is dead, or the sender.
If the button is pressed repeatedly the LCD steps through a bunch of diagnostics, (mine showed I had a charging problem). I will list as much info on these displays that I can check out should it be of interest. So far this is what I think happens.....
1. All LCD characters are displayed. All gauges step up/down. Warning lights all on.
2. Fuel remaining in tank? (appears to be in litres even though its a UK car!)
3. This shows '0.0' until the car is started then a number shows that varies with throttle (Fuel flow?)
4. Fault codes. This is a four digit/letter? code. Mine showed an 'h' in the last position (_ _ _ h) and a charging fault alarm on the graphics display (in red). The digit code can be reset by pressing the Odo' reset button, the graphics display stays put though.
Once the errors are cleared, or if there were no stored faults the display just shows four dashes, ie. _ _ _ _
The displays continuously cycle around these functions as the button is pressed.
Removing the keycard or pressing the reset clears the displays back to normal.
Even if its of no real use, watching the gauges 'dance' can keep the kids amused for hours
PLEASE NOTE I HAVE NO WAY OF KNOWING IF THIS WILL STUFF ANYTHING LONGTERM...
PLEASE USE WITH CAUTION.....
I'VE USED THIS 'HACK' OVER A DOZEN TIMES OVER THE WEEKEND SINCE I FOUND IT AND IT ALWAYS RESETS OK..... BUT YOU NEVER CAN TELL....... I WILL CHAT WITH A TAME RENAULT MECHANIC THAT I KNOW ASAP...
I still haven't fixed the charging alarm that it shows up... Strange thing is, in normal operation the charging all works fine with no alarms..
Maybe this feature just shows a fault history...similar to the OBD2 system? Anyone know?
SEE POST #10 FOR UPDATES
Cheers
Bob
Currently in bobford100's garage:
Laguna II 2.0 IDE Privilege VF1BG0N
Last edited by bobford100; 29th May 2007 at 01:50 PM. Reason: Update details and add warnings..
bobford100 is offline   Reply With Quote Quick reply to this message
The Following 2 Users Say Thank You to bobford100 For This Useful Post:
nonamewayne (15th October 2010)
5 Lastest Threads by bobford100
Laguna II heated front window...?? Electronics bobford100 7 1515 3rd June 2007 01:05 PM
Renault Laguna II - Dashboard diagnostic Electronics OliveMegane 20 23296 28th May 2007 01:59 PM
Laguna II petrol filler door. Bodywork bobford100 6 1120 27th May 2007 06:41 PM
Sponsored Links
Advertisement
Old 28th May 2007   #2
5th wheel
5th wheel is
has no status.
Platinum member
5th wheel's Avatar
good post bobford.
welcome to the forum.
__________________
ONCE A BLUE ALWAYS A Blue.
A FRIEND IN NEED~~~IS A PEST.GET RID OF HIM
Currently in 5th wheel's garage:
56 focus c.max 1.6 zetec / 07 6x2 440A M.A.N
5th wheel is offline   Reply With Quote Quick reply to this message
Old 28th May 2007   #3
bobford100
bobford100 is
has no status.
Junior Member
Threadstarter
Hi 5th wheel,
Thanks for the welcome.
Cheers
Bob
Old 28th May 2007   #4
david geoghegan
david geoghegan is
has no status.
Diamond member
david geoghegan's Avatar
hi bobford super post, as they say u learn something new every day cheers
Currently in david geoghegan's garage:
2004 renault laguna II 1.9dci
david geoghegan is offline   Reply With Quote Quick reply to this message
Old 28th May 2007   #5
bobford100
bobford100 is
has no status.
Junior Member
Threadstarter
Hi David,
No problem, hope it helps..
Cheers
Bob
Reply
Tags
dashboard, diagnostic, laguna, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Copyright 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
