Grand Scenic. Where is the Pollen Filter? - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Heating & cooling
Notices
Heating & cooling A place to discuss heating, air-con etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Heating & cooling
Reply
Thread Tools Search this Thread Display Modes
Old 31st May 2007   #1
ollyshorey
ollyshorey is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I hope somebody can help me.
I have a 2005 (54) Grand Scenic, and I am wanting to change the pollen filter.
However I have searched and just cannot find it.
Some of the other posts talk of it being under the foot wel however it just is not there!
I spoke to the dealer, and he seemed to think that it was behing the engine.
Perhaps you may know? I am thinking there must be an easyish process to get it out too.
Many thanks,
Olly.
Currently in ollyshorey's garage:
2005 Grand Scenic 1.5 Dci Dynamique.
ollyshorey is offline   Reply With Quote
5 Lastest Threads by ollyshorey
Grand Scenic. Where is the Pollen Filter? Heating & cooling ollyshorey 4 2188 31st May 2007 09:03 AM
Sponsored Links
Advertisement
Old 31st May 2007   #2
ottoman
ottoman is
has no status.
Platinum member
Nominated 1 Time in 1 Post
Hello & Welcome to the Forums Ollyshorey
It is in the glove compartment behind a panel.
Do a search on the Forums under " Pollen Filter " and you will find some help on changing it .
Ottoman
ottoman is offline   Reply With Quote
Old 31st May 2007   #3
mtottaman
mtottaman is
has no status.
Member
mtottaman's Avatar
I believe on the Grand Scenic the Pollen filter is in the engine bay. To get better access remove plastic engine cover which just pulls off of 4 clips 2 top and 2 bottom. Then centrally if you get a torch to make it easier to see just above the engine towards the back of the engine bay you should see a black plastic cover about 2 inches high and about 8 inches wide with a catch at each end. Turn the two catches to remove the cover and then gently pull out the filter. It's all a tight fit but apart from that fairly easy
Currently in mtottaman's garage:
2004 Renault Grand Scenic 2.0 priv auto
mtottaman is offline   Reply With Quote
Old 31st May 2007   #4
mtottaman
mtottaman is
has no status.
Member
mtottaman's Avatar
Comments on filter being in footwell/behind glovebox relate to the older scenics with air conditioning
Old 1st June 2007   #5
ollyshorey
ollyshorey is
has no status.
Junior Member
Threadstarter
Thanks for the help.
I eventually found it, and it was under the bonnet, however it is more above the engine on the bulkhead.
Once I removed the cover I could feel two plastic lugs.
The best way I found to pull it out was to grab the lower one and lift it up. Then it just pulls out.
Thanks again,
Olly.
Reply
Tags
filter, grand, pollen, scenic
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
