1.5dci 2007 megane 86 - starting problems & fault codes - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 29th November 2013   #1
Bencil
Bencil is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi everyone, I am having some intermittent starting problems with my 1.5dci 86 megane 2007. Starts fine roughly 4 out of 5 times, if not then starts 2nd try no problem.
I bought an obd2 reader which works with torque on my phone. 2 fault codes come up which reappear after being cleared: p0670 and p0016 which are "glow plug control module control circuit/open" and "crankshaft position - camshaft position correlation"
I found a defective glow plug, which I replaced and have replaced the tdc/crankshaft sensor. However the fault codes reappear...
Any ideas what the problems could be? Camshaft sensor? Wiring?
Cheers, Ben
Bencil is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Bencil
Megane 1.5dci 2007 - dashboard fan control lights... Electronics TazzyK 7 4822 2nd December 2013 12:52 PM
1.5dci 2007 megane 86 - starting problems & fault... Engines Dancingdad 6 2065 29th November 2013 12:48 PM
Sponsored Links
Advertisement
Old 1st December 2013   #2
Bencil
Bencil is
has no status.
Junior Member
Threadstarter
Re: 1.5dci 2007 megane 86 - starting problems & fault codes
Anyone!? Please!
Old 1st December 2013   #3
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
The fault codes you have are generic and not Renault specific so may be totally erroneous and may be totally misleading. Renault use a different protocol in their ECU's and very few code readers are fully compatible. I suggest you have the fault codes read by a Renault compatible code reader otherwise you may be chasing faults which don't really exist.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 1st December 2013   #4
Sparky72
Sparky72 is
has no status.
Diamond member
Sparky72's Avatar
Smile Re: 1.5dci 2007 megane 86 - starting problems & fault codes
If you have a multi meter you can test the glow plugs in place they should be no more than 2 ohms.
__________________
If you like what someone's said, Thank them. If you find the solution to your problem post it and help others help them selves.
Currently in Sparky72's garage:
04 Espace 2.2DCI, 04 Scenic 1.9DCI, 03 Fiat Stilo died :-(.
Sparky72 is offline   Reply With Quote Quick reply to this message
Old 30th December 2013   #5
Bencil
Bencil is
has no status.
Junior Member
Threadstarter
The glow plug fault code has disappeared. I have replaced the tdc sensor however no change to the starting problems and p0016 code. I think I may have to get renault to have a look
Reply
Tags
15dci, 2007, codes, fault, megane, problems, starting
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
