Renault Megane 1 - Intermittant Starting Problems - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Megane
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Megane
Reply
Thread Tools Display Modes
Old 16th June 2007   #1
Jean Pereira
Jean Pereira is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Over last 3-4 weeks my car has not started the first time each day, i.e. when cold. It turns over but won't start. If I left it for a couple of mins, it often did start.
Changed spark plugs and it started first time for a few days. Now, as well as not starting first thing, if it does start, it can cut out when idling so you have to keep revving it whilst stationary. Once its warmed up, it doesn't cut out.
Then, if you leave the car for a short or long period of time, it may not start. Had Green Flag out and he put a tester between the distributor cap and coil and reseated connections to the coil and it started fine. Two days later, it wouldn't start and hasn't started since.(4 days now).
I keep reading about TDC sensor. Should I replace that? Do I have to get a garage to do it and how much is it?
Amny help appreciated.
Jean
Currently in Jean Pereira's garage:
Renault Megane 1400
Jean Pereira is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Jean Pereira For This Useful Post:
5 Lastest Threads by Jean Pereira
Renault Megane - Alternator Belt Snapped,Now... Engines Lagdti 11 4982 3rd October 2007 08:46 PM
Jean again with another problem Welcome to RenaultForums leroy 2 1401 17th June 2007 11:54 PM
Renault Megane 1 - Intermittant Starting Problems Megane ezr0 76 127151 16th June 2007 02:25 PM
Sponsored Links
Advertisement
Old 16th June 2007   #2
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Welcome to the forum.
What age Megane do you have?
It does sound like a Top Dead Centre sensor fault,but the locations of them vary from different ages and engine types.
EDIT;Sorry,I've just seen that it's an R reg!.I guess it's the 8 valve engine?
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 17th June 2007   #3
christyrrell1
christyrrell1 is
has no status.
Junior Member
christyrrell1's Avatar
Unhappy Non-starting Megane
I have an X-reg Megane Auto Expression 1.6 and it is also experiencing problems starting. The engine turns over when the key is turned but frequently doesn't fire, particularly when the weather is warm, the engine is hot or the fuel tank is even slightly less than full - I have to fill up every two days.
I had it in the garage yesterday and was pretty much told I was lying as there was no way it could happen, but this must be a common problem, because the Clio I had before (1.4 Alize, 2000) did exactly the same.
Any ideas?
Currently in christyrrell1's garage:
2001 renault Megane Auto Expression 1.6
christyrrell1 is offline   Reply With Quote Quick reply to this message
Old 17th June 2007   #4
alex21
alex21 is
has no status.
Diamond member
hi and welcome to the forums, lol thats funny i had a car the exact same as yours on friday with the same fault, the cars not burgandy is it lol
the fault was the tdc sensor, its very common and gives these symptoms that your describeing, i had a spare sensor in my box but i found out it was no good as the automatic sensor has dowles to secure it to the box lol.
so i ended up just cleaning it for the customer as he was in a rush, gave him my mobile number and he phoned this morning to say his car has been brand new. so you could try this m8, its worked quite a few times lol.
__________________
Old Mother Hubbard , Went to the cupboard to fetch her poor dog a bone.
When she bent over Rover took over, And gave her a bone of his own:D
Currently in alex21's garage:
vx astra mk5 2l turbo
alex21 is offline   Reply With Quote Quick reply to this message
Old 17th June 2007   #5
christyrrell1
christyrrell1 is
has no status.
Junior Member
Cool - is that my symptoms Alex, or Jeans?
It certainly wasn't my car - it's silver!
I'll get it checked out - thanks very much.
Reply
Tags
intermittant, megane, problems, renault, starting
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
