Multiple Faults for 1.9 dCi Scenic - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 18th December 2013   #1
Jdhawl
Jdhawl is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I recently bought a Renault Scenic 2007. Two months ago the Check injection light would appear and then go away. I noticed that when I would have lower RPM's/Speed on start off due to a hill, the light would come on. A month ago the light came on and stayed on. When the light is on the car has half the power. It will get up to speed, but takes a long time to do so. Today I had a diagnostic test done and here are the error codes:
DF046
DF032/033/034
DF025
DF004
DF308
Any help is much appreciated.
Currently in Jdhawl's garage:
2007 Renault Scenic 1.9dCi
Jdhawl is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Jdhawl
Multiple Faults for 1.9 dCi Scenic Engines TTT 4 2942 18th December 2013 09:45 PM
Sponsored Links
Advertisement
Old 19th December 2013   #2
TTT
TTT is
has no status.
Platinum member
Technical Supremo
TTT's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 4
Re: Multiple Faults for 1.9 dCi Scenic
Try putting the fault codes in Google.
Cheers.
__________________
Please take the time to enter your vehicle details in the "What's current in your garage?" box, this will help other members help you!
To do this:
Click on the "Quick Links" tab at the top of the page
> then click on "Edit Your Details"
> scroll down the page and put your vehicle details in the "What's current in your garage?" box
> come down to the bottom of the page and click "Save Changes"
You will now have a box with your vehicle details at the bottom of every post you make
Currently in TTT's garage:
2001 Renault Laguna II 1.9dCi Dynamique Sport Tourer
TTT is offline   Reply With Quote Quick reply to this message
Old 19th December 2013   #3
Jdhawl
Jdhawl is
has no status.
Junior Member
Threadstarter
Yeah, I did. I already have the description of each fault. I think DF025, DF004, DF308 are the main problems.
DF025 Preheating Unit Diagnostic Line
DF004 Turbo Charging pressure sensor circuit
DF308 Particlate Filter blocked or restricted flow
I thought maybe somebody else had something similar in the pass, and knew which fault was priority, possible causing the other ones. Thanks for your help.
Old 19th December 2013   #4
Jdhawl
Jdhawl is
has no status.
Junior Member
Threadstarter
I forgot to mention that this is a Diesel/manual.
Old 19th December 2013   #5
TTT
TTT is
has no status.
Platinum member
Technical Supremo
TTT's Avatar
DF025 Preheating Unit Diagnostic Line:
From what I can find this could just be that you have a glow plug off.
Some info:
http://www.renaultforums.co.uk/showthread.php?t=84284
http://www.meganeownersclub.co.uk/fo...hp?f=2&t=13217
http://www.bba-reman.com/forums/Topic92392-1-1.aspx
DF308 "Particulate Filter blocked or restricted flow:
As far as I can see by searching " means just that. The particle filter will need to be regenerated possibly by having a forced regeneration performed.
Some info here:
http://www.diamondmotors.net/archives/864
DF004 Turbo Charging pressure sensor circuit:
Could this be because the Particle filter is blocked and the engine cant breath properly?....if it can't get out it can't get in so to speak.
Cheers.
Reply
Tags
dci, faults, multiple, scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
