Renault Espace - Multiple Problems - Page 2 - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Cars & motoring
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Cars & motoring
Reply
Thread Tools Display Modes
Old 15th July 2007   #6
Eagleboy
Eagleboy is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
i have had a number of egr problems and odd engine faultts in the past, i now only use BP or Shefuel and put about one in 5 fills use ultimate or similar, have had no faults since and get 2-3 miles per gallon more. Avoid supermarket fuels at all cost they do not have the additives to keep the engine clean
Currently in Eagleboy's garage:
2010 dynamique Espace
Eagleboy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 16th July 2007   #7
Steve's Espace
Steve's Espace is
has no status.
Junior Member
Threadstarter
Just an update having carried out some tests which may strike a chord with someone to point at the source of the faults.
On the injection faulty - I've found that it occurs after I've drive for about 6 - 7 minutes (4 minutes @ 30-40 mph) enter motorway accelarate to 70 mph, spend 2 minutes @70mph - take my foot off the accelarator slowing from 70mph to 50mph (approaching roadworks). This is having started from cold after a night in the drive and is totally repeatable. Once the engine has been run during the day it never re-occurs.
On the ABS and ESP problem it only occurs when I put the steering on full left lock. This is also totally repeatable. Doesn't happen on full right lock.
So over to you guys, anyone had a similar set of circumstances - hopefully with a solution.
Steve
Currently in Steve's Espace's garage:
2003 Espace DCI Expression
Steve's Espace is offline   Reply With Quote Quick reply to this message
Old 20th July 2007   #8
Steve's Espace
Steve's Espace is
has no status.
Junior Member
Threadstarter
It gets better and better, just been to my local Renault specialist to run diagnostics on it and there were 25 faults in the memory:-
DF128 Robotised Gearbox or at CAN connection, fault on connection
DF021 Engine immobiliser Unidentified electrical fault
DF002 Throttle potentiometer circuit coherence between track 1 and track 2
DF136 Accel pedal motorised throttle circuit, Coherence between the pedal position and the motorised throttle position
DF022 Computer, Computer fault: motorised throttle command
DF022 Computer, Memory zone fault
DF134 Instrument panel connection, Unidentified electrical fault
DF131 AT convertor
DF082 Petrol <-> LPG Connection, Unidentified electrical fault
DF132 Heated Windscreen, Unidentified electrical fault
DF249 Automatic transmission, Torque reference value
DF083 ABS-> Injection interface, Unidentified electrical fault
DF285 Air heater
DF055 Cylinder 4 Injector circuit, Unidentified electrical fault
DF137 Motorised throttle, Motorised throttle limits search fault
DF137 Motorised throttle, Programmed values
DF006 Knock sensor circuit, OBD fault
DF003 Air temperature sensor, OBD fault
DF004 Water temperature sensor circuit, OBD fault
DF005 Pressure sensor circuit
DF128 Robotised Gearbox or at CAN connection, OBD fault
DF017 Flywheel signal information, OBD fault :flywheel target
I don't believe I'm really getting all of these faults so does anyone know if there is a common point on all of these such as a connector.
Steve
Old 20th July 2007   #9
mr espace
mr espace is
turning into mr clio !!
Platinum member
mr espace's Avatar
Nominated 0 Times in 7 Posts
Reading through that i would say an earth fault as all the things relate to the engine or engine loom !!
Currently in mr espace's garage:
espace escort cabriolet subaru legacy clios etc !!
mr espace is offline   Reply With Quote Quick reply to this message
Old 23rd July 2007   #10
Steve's Espace
Steve's Espace is
has no status.
Junior Member
Threadstarter
My local Renault guy cleared all the codes and it seemed better for a day and then yes back to getting the ESP/ABS fault and the fuel injection fault. One thing I have noticed is that I never get the 2 sets of faults at the same time .......suspicious or not. Any ideas
Steve
Reply
Tags
espace, multiple, problems, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
