Quick dci egr blanking question - Page 3 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 23rd March 2014   #11
bugsb
bugsb is
at home
Platinum member
bugsb's Avatar
Nominated 14 Times in 11 Posts
Nominated TOTW/F/M Award(s): 2
Re: Quick dci egr blanking question
Quote:
Originally Posted by TTT View Post
On my laguna I left the valve plugged in but rotated it approx 180 degrees in its hole...this allows the valve to operate as normal but it blocks the ports that allow exhaust gasses into the inlet. So the valve opens and closes as normal but no gasses get through....happy days
The only problem with doing this is that only one of the bolt holes lines up, but if you place a washer on one of the other bolt holes it presses on the edge of the body of the ERG valve to help hold it in place. (2 bolts in position)
My valve has been like this for a couple of years now with no problems and no warning lights, and no reduced MPG like you get when simply unplugging the valve !
Cheers.
i did the same on my 1.5dci but was able to line up 2 bolts by enlarging one hole on the egr valve
Ron
Currently in bugsb's garage:
MGF 1.8 1999/honda hrv 2002
bugsb is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 23rd March 2014   #12
Chrisd346
Chrisd346 is
has no status.
Junior Member
Threadstarter
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Thank you everyone for the help. I might try spinning it around 180 then to see if that works! So it doesn't line up perfectly when rotated?
Currently in Chrisd346's garage:
2002 Laguna 1.9dCi
Chrisd346 is offline   Reply With Quote Quick reply to this message
Old 23rd March 2014   #13
Alex3
Alex3 is
has no status.
Diamond member
The valve is already in 2 parts. Spin the inner, ported part a half turn so that one bolt locates. Bolt the outer electrical part with the 3 bolts as normal. The EGR will continue to function but exhaust gases are cut off.
Alex3 is offline   Reply With Quote Quick reply to this message
The Following 2 Users Say Thank You to Alex3 For This Useful Post:
Phil48 (23rd March 2014), TTT (23rd March 2014)
Old 23rd March 2014   #14
TTT
TTT is
has no status.
Platinum member
Technical Supremo
TTT's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 4
Thumbs up Re: Quick dci egr blanking question
Quote:
I didn't think of doing it that way....I turned the whole valve.
Just turning the inner part as you describe is a better idea
Cheers.
__________________
Please take the time to enter your vehicle details in the "What's current in your garage?" box, this will help other members help you!
To do this:
Click on the "Quick Links" tab at the top of the page
> then click on "Edit Your Details"
> scroll down the page and put your vehicle details in the "What's current in your garage?" box
> come down to the bottom of the page and click "Save Changes"
You will now have a box with your vehicle details at the bottom of every post you make
Currently in TTT's garage:
2001 Renault Laguna II 1.9dCi Dynamique Sport Tourer
TTT is offline   Reply With Quote Quick reply to this message
Old 23rd March 2014   #15
Chrisd346
Chrisd346 is
has no status.
Junior Member
Threadstarter
Ok i have this done now. The inner section was a bit stubborn to remove but got it out eventually. I turned it 180 degrees and lined it up with one hole. I turned the outer part the same to line it up with the inner sections holes(is this right) but was only able to fit one bolt as the manifold they fit on was was blocking half of the other 2 holes. Hopefully I've made myself clear enough lol.
Car does feel a little smoother but haven't taken it much more than a few miles so any other benefits remain to be seen.
2002 Laguna 1.9dCi
Reply
Tags
blanking, dci, egr, question, quick
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
