Laguna II 1.9dCi - starting problems - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 27th September 2007   #1
Njnnjn
Njnnjn is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My Laguna II have just been returned from the garrage, where the have replaced the turbo and the EGR?, and flushed the InterCooler (It took four weeks!).
They told me, that the battery have to be replaced (there was no problem with the battery before the repair), and they have had to jump-start it more than once.
This is two days ago, where we have had no problems.
Then this morning, it almost couldn't start, but did when i switches the lights off.
One hour later, i was not able to start the car.
I tried to jumpstart it, with no success.
Then i replaced the battery, but it still won't start, and the battery-indicator is on.
It doesnt turn the starter at all, and there is no sounds when i push the startbutton.
The generator was replaced 8 month ago.
Help!!!
Currently in Njnnjn's garage:
2001 Renault Laguna II 1.9dCi
Njnnjn is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Njnnjn
Half of the EGR stuck, and flange destroyed! Engines Njnnjn 4 2352 15th August 2009 11:41 AM
Laguna II 1.9dCi - starting problems Engines madnoel10 8 1540 27th September 2007 01:09 PM
Sponsored Links
Advertisement
Old 27th September 2007   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
For whatever reason it appears the battery isn't holding its charge - could be a duff battery or a current leak which is draining the battery. I suggest you check all cable connections including the engine earth lead.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is online now   Reply With Quote Quick reply to this message
Old 27th September 2007   #3
Njnnjn
Njnnjn is
has no status.
Junior Member
Threadstarter
I swapped the battery to brand new AND charged one. Still unable to start.
The lights a.s.o. works fine.
Old 27th September 2007   #4
madnoel10
madnoel10 is
has no status.
Technical Supremo
Hi Njnnjn - I take you have keycard ignition - if so it possible there is a fault there somewhere.
Honda Civic 1.4l
Old 28th September 2007   #5
Njnnjn
Njnnjn is
has no status.
Junior Member
Threadstarter
What the f... !!!
In the afternoon, we were going to tow the car, AND THEN THE CAR STARTED WITH NO PROBLEMS AT ALL!!
Now i'm confused?
The only "suspicious" thing i can se now, is that the warninglights in the instrument-panel flashes in a strange manner, after i stopped the engine.
When i pull out the key-card, everything turns off and looks normal.
When put in the keycard, after a couple of seconds, the lights "STOP" and battery is lit, but maybe this is normal?
By the way, i'm impressed by the quick responses in this forum!
Best regards,
Njnnjn (From Denmark).
Reply
Tags
19dci, laguna, problems, starting
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
