Draining the Fuel Tank Megane Scenic 1.9TDI - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 1st November 2007   #1
pin1onu
pin1onu is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I've got an S Reg Renault Scenic 1.9Dti with a blown turbo which is set to go to a scrap dealers. However before it goes I want to recover the £50 worth of fuel that I'd just put in before the turbo went pete.
I've checked a few forums and concluded that as there is no drain-off valve it would be best to disconnect the inlet pipe from the fuel pump and let the fuel drain off that way. This method seemed to work at first and I got about a quarter of fuel out of the tank before it stopped. Now nothing further will come out. I suspect atmospheric pressure is not going to be enough to get the the rest of the fuel out. If if is the case I guess I'll need to obtain a handpump from somewhere.
Can someone confirm if I'm on the right track.
If I am on the right track could someone suggest where I can obtain a handpump from and ballpark figures on a price.
Ian
Currently in pin1onu's garage:
Renault Megane Scenic 1.9 DTI
pin1onu is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by pin1onu
Draining the Fuel Tank Megane Scenic 1.9TDI Engines madnoel10 3 6023 1st November 2007 04:30 PM
Sponsored Links
Advertisement
Old 1st November 2007   #2
stef123
stef123 is
Platinum member
stef123's Avatar
Ian
hey,
Sorry to make you sound silly but did you open the fuel cap when you disconnected the inlet pipe from the pump? if its on the bottom of the tank then i dont see why its not coming out
Sorry for my lack of knowledge but its one of them simple things that easily missed i guess.
I hope someone gets back to you with some good solid advice.
stef123
Currently in stef123's garage:
2006 Ford Mondeo ST TDCI
stef123 is offline   Reply With Quote Quick reply to this message
Old 1st November 2007   #3
pin1onu
pin1onu is
has no status.
Junior Member
Threadstarter
Yes fuel cap was removed.
Old 2nd November 2007   #4
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Hi Pin - if it going to the scrappers why not just punch or drill a hole in the ass of the tank or remove the fuel tank sender unit and syphon the remainder out.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Reply
Tags
19tdi, draining, fuel, megane, scenic, tank
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
