Renault Laguna 2 - Starting Problem - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 3rd December 2007   #1
symie
symie is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Unhappy Renault Laguna 2 - Starting Problem
can anyone shed some light on this intermittant prob car is a 2002 1.6 16v laguna dynamique when i press start button the starter does nothing but all dash lights go out as if car has started then it switches its self back off after about 30 secs ie ign lights back on sometimes it can take 4-5 pushes of the button before it starts other times it starts first time anyone came across this prob before
Currently in symie's garage:
laguna ii 1.6 dynamique
symie is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by symie
Renault Laguna 2 - Starting Problem Engines 12 2590 3rd December 2007 07:51 PM
Sponsored Links
Advertisement
Old 3rd December 2007   #2
symie
symie is
has no status.
Junior Member
Threadstarter
Unhappy laguna 2 starting problem
sorry folks forgot to add car went to dealer for diagnostics check but surprise surprise the car started ok and no fault showed also had r a c out and the car started 1st time for him
very confused now and not much hair left many thanks in anticipation
Old 3rd December 2007   #3
davesss
davesss is
Calm Cool and Collected
Tourerman
davesss's Avatar
Nominated 0 Times in 2 Posts
Nominated TOTW/F/M Award(s): 3
I didn't read your first post, the problem is probably the TDC sensor, this does not show up on the computer at the dealers.
Put TDC sensor in the search box and look through the thread for replacing it
Cheap and easy fix.
__________________
A problem well stated is a problem half solved !
Currently in davesss's garage:
2002 Laguna Sports Tourer 1.8 Dynamique Moondust VF1KGOB, Fiat Siecento Micheal Schumaker, Kawasaki KLE M/Cycle and a cheap Mountain Bike.
davesss is offline   Reply With Quote Quick reply to this message
Old 4th December 2007   #4
symie
symie is
has no status.
Junior Member
Threadstarter
Smile laguna 2 starting prob
sorry davesss logged off after your reply will try tds sensor hope this cures prob many thanks for your help
Old 4th December 2007   #5
AbuQaoud
AbuQaoud is
has no status.
Edit
Posts: n/a
Laguna not starting :-(
Hi, i have a problem with my laguna 2. i parked up today and pressed the switch to turn the car off but left the key card in. then after 10 minutes i pressed it to start it but it just went dead. so i toke it out and tried again but nothing.
so i opened the door and i heard a ticking noise from near the steering wheel, the red light was flashing, i couldnt lock or unlock the doors. i put the key card in again and nothing happened even the locking button near the hand brake didnt work. now i put the key card in and nothing happens the key card light flash when i press them just like thye should. so i had to have it recovered to the renault dealer to have a diagnostics check, which i will get the results for in 2 days. Im thinking it might be something to do with the immobeliser, any ideas anyone. Thanks alot and sorry for the long post.
Reply
Tags
laguna, problem, renault, starting
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
