Renault - Scenic II - Window Regulator Brackets/Clips - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Scenic
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Scenic
Reply
Thread Tools Display Modes
Old 26th December 2007   #1
ottoman
ottoman is
has no status.
Platinum member
Nominated 0 Times in 1 Post
Window Regulator Brackets are available on ebay now.
I'm not sure if these parts are available from Renault I would check the availability and price from your local Renault parts centre first before bidding/buying from ebay
RENAULT MEGANE SCENIC WINDOW REGULATOR BRACKET 2003-07 on eBay, also, Renault, Car Parts, Cars, Parts Vehicles (end time 29-Dec-07 19:56:27 GMT)
The Pic above shows the original part and the new modified part.
I believe Renault will change a damaged part if the vehicle is under 4 years old .
ottoman is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to ottoman For This Useful Post:
Stylot (27th December 2012)
5 Lastest Threads by ottoman
Whats This ? General Chat The big red bus 32 8328 2nd March 2009 11:52 PM
Software - Image Mapper Photography Club ottoman 8 3772 16th February 2009 06:12 PM
Sponsored Links
Advertisement
Old 10th March 2008   #2
hzv4vf
hzv4vf is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Smile Scenic (2004) - Window Regulator Bracket
This is my first post - I hope someone finds it useful.
Needed to replace my passenger side window regulator bracket today - it had snapped exactly as the picture shown above.
Went to local Renault dealer (Wolverhampton) and bought a pair of brackets for £3.10. They only come in pairs from Renault. He did say that the only reason you could buy them (without having to buy the whole regulator) was because there had been a recall on them, and that they are being replaced during services.
I replaced the passenger one myself - very easy job.
Once you've taken the door panel off (desribed elsewhere on this forum), the regulator comes out of the door by removing a further 2 torx screws (one is already removed as part of taking the door panel off). Disconnect electrical connection plug from motor (on the regulator frame).
With the regulator out of the door, slide the new bracket onto the regulator and attach the two ends of the regulator cable to the bracket - all while the regulator is out of the door.
Once bracket is attached to the regulator, re-fit the regulator into the door with the 2 torx screws. Re-connect the electrical connection plug to the motor and use electric window switch to move the green bracket into view - if it isn't already!
Manually slide the window down towards the green bracket and align the small hole in the bottom of the window with the screw hole in the bracket. Fit the small torx screw that came with the new style bracket, into the green bracket to fix the bracket to the window.
Job done - apart from re-fitting the door panels.
(Sorry I didn't take photos during the job).
Currently in hzv4vf's garage:
2004 Renault Scenic II 1.9dDI Dynamique
hzv4vf is offline   Reply With Quote Quick reply to this message
The Following 2 Users Say Thank You to hzv4vf For This Useful Post:
chrisman (8th April 2012), jeanjohn (13th April 2012)
Old 10th March 2008   #3
ottoman
ottoman is
has no status.
Platinum member
Threadstarter
Good informative post hzv4vf
Yeah at one time you had to buy the whole regulator, Strange when Renault had to start footing the bill these parts suddenly became available .
£3.10 a cheap repair apart from your time
Deadslow (9th May 2013)
Old 8th July 2008   #4
abdr1
abdr1 is
has no status.
Member
Scenic window regulator bracket
I've had one of these break on my Scenic. I contacted my local Renault dealer who said that although the car is (just) under 4 years old, because the mileage is over 50k, they cannot replace the bracket!
Currently in abdr1's garage:
2004 Scenic 1.9dCi
abdr1 is offline   Reply With Quote Quick reply to this message
Old 11th October 2008   #5
Scenic Demon
Scenic Demon is
has no status.
Member
Scenic Demon's Avatar
i bought one of these regulators off ebay a couple of months ago to replace the broken one on my n/s rear door.
i bought a haynes manual to tell me how to do the job, and the cost of the bracket, plus the manual was still less than a third of what evans halshaw renault wanted to do the job for me
Currently in Scenic Demon's garage:
11 Reg Skoda Octavia 1.6 MPi SE and a 2001 Yamaha YZF600R Thundercat
Scenic Demon is offline   Reply With Quote Quick reply to this message
Reply
Tags
brackets or clips, ebay, regulator, renault, scenic, window
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
