Renault Clio Cambelt change - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 3rd January 2008   #1
Henbury
Henbury is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question Renault Clio Cambelt change
My 2003 Renault Clio 1.2 Expression will be 5 years old soon. It has done 32000 miles, with full Renault service history. When should I have the cambelt changed? I have heard that it is a good idea to have the water pump changed at the same time - is this a wise precaution? What do Renault recommend.
Currently in Henbury's garage:
2003 Clio
Henbury is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Henbury
Windscreen Washers / Wipers fault Electronics Henbury 0 1046 3rd September 2011 11:16 AM
Renault Clio Cambelt change Engines SomersetScott 4 24542 3rd January 2008 09:01 AM
Renault Clio - Drivers Door Misaligned Bodywork madnoel10 11 3462 7th December 2007 09:08 AM
Sponsored Links
Advertisement
Old 3rd January 2008   #2
ottoman
ottoman is
has no status.
Platinum member
Nominated 0 Times in 1 Post
Hi Hebury,
72,000 or 5 years is the recommended interval for a cambelt change on your model.
Some recommend that you change all the belts and water pump at the same time as if the pump goes after the change you will have to change all the belts again at considerable cost.
I would get a price from a Renault workshop and also a good independent with some Renault experience as the cost would be considerably less than Renault.
ottoman is offline   Reply With Quote Quick reply to this message
Old 29th May 2012   #3
Kristoph2000
Kristoph2000 is
has no status.
Junior Member
Re: Renault Clio Cambelt change
Hi all,
I have just found out that my Clio has done over 100 k and to my knowledge the cam belt has not been changed. Should i get this done ASAP???
Does any one know how much this should roughly cost?
Thanks.
Kristoph2000 is offline   Reply With Quote Quick reply to this message
Old 29th May 2012   #4
yozer13
yozer13 is
has no status.
Junior Member
i would get it changed and do the waterpump as while your there its worth replacing.
and dont skimp on the parts water pump, belt and tensioner as you dont want these parts to fail and its will be real expensive. the belt snapped on my mrs clio and then she gave it to me to fix, lucky as it only bent 5 valves and lucky being a fitter im able to do it myself as for a garage to do it would cost loads, it cost me around £200 in parts to repair and i did it myself so no labour charge.
i would get it done as it could save you a lot of money on either repair or have a new motor fitted. besides you cant put a price on piece of mind,
as for a price to fit i dont know but i know for my dci the belt kit is around £85 and the book time is roughly 2.4hrs so they may round it to 3 hrs at £50 -£60 an hr .
Currently in yozer13's garage:
nissan kubistar 1.5dci 2005
yozer13 is offline   Reply With Quote Quick reply to this message
Old 30th May 2012   #5
SomersetScott
SomersetScott is
nuts..
SomersetScott's Avatar
I'd always change waterpump, & tensioners even if they look okay with cambelt as these parts are very important. if water pump leaks and coolant gets on the belt you'd need another belt again anyway.
Worst case senario bearings siease, cambelt snaps or slips off and you end up with a mess and a hefty bill.. So yeah, 'good practice'..
Sounds like you've got a few years motoring before you need to anyway, lucky you :-)
__________________
Currently in SomersetScott's garage:
Mégane 1.5dCi Rush (Mk 2, 2005), Clio 1.5dCi (Mk 2, 2005) & Rover 100 K-series 1.1L (1996)
SomersetScott is offline   Reply With Quote Quick reply to this message
Reply
Tags
cambelt, change, clio, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
