renault espace renault espace hesitation on acceleration and stalls - Page 2 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 13th January 2008   #6
liqiudfeline
liqiudfeline is
has no status.
Junior Member
Threadstarter
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
engine came out complete
then changed head gasket just in case turn out it had gone
never heard engine running
got it from scrap yard
but it runs nice if i do not touch pedel
could the timing bit out
thought it would back fire if wrong
liqiudfeline is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 13th January 2008   #7
Tiggerz_SRi
Tiggerz_SRi is
doesnt put up with bullys ;)
Platinum member
Tiggerz_SRi's Avatar
Nominated TOTW/F/M Award(s): 2
yes if the timing out it will do that as the inlet/exaust valves can open to early/late etc which fooks up the combustion cycle.
Need a light gun to test that! Also if its 1 tooth out it can run poor.
Currently in Tiggerz_SRi's garage:
Audi a4 v6 avant, used to have bmw 525d se estate, 2001 Toyota Previa 2.4 VVTi GLS, '98 R FORD Galaxy 2.3 Ghia X a Espace III 2.2dT RXE and a Lag I 1.8RT!
Tiggerz_SRi is offline   Reply With Quote Quick reply to this message
Old 13th January 2008   #8
TheCleanerLeon
TheCleanerLeon is
has no status.
Diamond member
TheCleanerLeon's Avatar
check if your car has a charcoal canister with solenoid valve, the porblem may lie there, as it is a small reserve of fuel the engine will use with a combination of throttle depress and temperature.
If there is a break/restriction in this system, the engine will momentarily be starved of fuel until the ECU detects it and rectifies.
Got the haynes manual for your car? that will let you know where the canister is.. its under the section 'emissions' or similar
Currently in TheCleanerLeon's garage:
2004 ClioII 1.5 dCi 100bhp
TheCleanerLeon is offline   Reply With Quote Quick reply to this message
Old 13th January 2008   #9
liqiudfeline
liqiudfeline is
has no status.
Junior Member
Threadstarter
well it idles at 1000 to 1100 with no misfire or back fire
when i did timing i set top to mark under cam cover
bottom to 0 on bell housing and with no1 spark out screw driver in place
but think i will check it again 2morrow
Old 13th January 2008   #10
liqiudfeline
liqiudfeline is
has no status.
Junior Member
Threadstarter
yes it has one of these got hynes manual
just out of intrest can you put the pipes on the wrong way round if so which way do they go to manifold
Reply
Tags
acceleration, espace, hesitation, renault, stalls
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
