Scenic - Spark Plug Change - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 4th February 2008   #1
alisonb
alisonb is
has no status.
Junior Member
alisonb's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Smile Scenic - Spark Plug Change
Hi, my husband has just given in and bought me a scenic! Fantastic car, loads of storage space, keep losing things!
I need some help, the spark plugs need replacing, but we are not sure where to start on this one! It's a 2.0 16v 2000 scenic, i believe the spark plugs are under the ignition coils? on top of the engine, at first glance could look like plug leads? if so, how easy, or otherwise, are they to replace and how please! thanks in advance, alison.
Currently in alisonb's garage:
2000 megane scenic 2.0rxe
alisonb is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by alisonb
tailgate window Bodywork ottoman 2 590 10th February 2008 09:23 PM
Scenic - Spark Plug Change Engines ottoman 4 4333 4th February 2008 01:12 PM
Sponsored Links
Advertisement
Old 4th February 2008   #2
coug3r
coug3r is
has no status.
Junior Member
This is for a Megane but I guess the same approach would work on a Scenic ?
Over the engine is a grey plastic cover. To see the coils or plugs this needs to be removed. You will then be able to see some leads. One above each cylinder. The leads are connected to the coils that are above the spark plug. To remove a coil, disconnect the lead and locate a hexagonal headed screw at the base of the coil. Undo this screw and the coil can be pulled out. The coil will have an o-ring so anticipate it being a little tight. Once the coil is off, you will be able to locate the spark plug. Remove the spark plug using an appropriate socket set. Fit the new plug and reassemble taking care to put back the same lead as you took off ( if replacing an entire set of plugs )
coug3r is offline   Reply With Quote Quick reply to this message
Old 4th February 2008   #3
alisonb
alisonb is
has no status.
Junior Member
Threadstarter
alisonb's Avatar
Thumbs up
Thanks, will give it a try later and see how i get on.
Old 4th February 2008   #4
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Are you changing the plugs to cure a misfire?.If so I suspect it's a coil causing it,although it's always a good idea to change the plugs at the same time as the coils.
Welcome to the forum by the way.
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 11th February 2008   #5
ottoman
ottoman is
has no status.
Platinum member
Nominated 0 Times in 1 Post
Moved to Engines
Retitled
ottoman is offline   Reply With Quote Quick reply to this message
Reply
Tags
change, plug, scenic, spark
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
