Clio 1.2 engine removal - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 7th February 2008   #1
clioeagle
clioeagle is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Is this do-able in the driveway? Would it be "easier" to not split and do an engine/box?
Do you have to drop the subframe as well? ( have seen several for sale on ebay with it still attached).
Alternatively what do you reckon labour hours for a garage to fit a replacement?
Do not want to scrap the car, it is an S reg with 60K.
Any thoughts appreciated.
Currently in clioeagle's garage:
1997 clio rt 1.2
clioeagle is offline   Reply With Quote
5 Lastest Threads by clioeagle
Clio engine identification how to....? Engines clioeagle 2 1539 1st July 2008 09:19 PM
More than one D7F? Engines clioeagle 4 2497 27th April 2008 09:26 PM
Hello Welcome to RenaultForums Oilyrag 2 280 7th February 2008 09:27 PM
Clio 1.2 engine removal Engines clioeagle 3 1249 7th February 2008 09:21 PM
Sponsored Links
Advertisement
Old 8th February 2008   #2
Alan Welch
Alan Welch is
has no status.
Member
[QUOTE=clioeagle;287420]Is this do-able in the driveway? Would it be "easier" to not split and do an engine/box?
Any thoughts appreciated. END QUOTE]
I haven’t removed an engine/box for a very long time so my thoughts are just thoughts.
I would imagine that the easiest way for a well equipped garage to change an engine is to remove the engine from below, complete with its drive shafts and/or front suspension. Then ‘on the floor’ separate off the gearbox etc.
I would have thought that such a garage and skilled mechanic would take ½ day to remove, ½ day to replace + the time taken to swap engines replace clutches whilst one is about it etc.
For the home mechanic like me, I would spend a lot longer removing the gearbox and then hoisting the engine out from above. However, I don’t know if with this engine there are any problems doing this.
I expect there will be a host of little things to test you though, like for example, overcoming the varnish glue that Renault use when sliding the splined drive shafts into their hubs. This cause me no end of headaches on a 1.2 Clio (P reg) when I was taking of the front hub carriers to change their bearings.
Good luck!
Currently in Alan Welch's garage:
other renault
Alan Welch is offline   Reply With Quote
Old 8th February 2008   #3
cph1984
cph1984 is
has no status.
Diamond member
cph1984's Avatar
Nominated 1 Time in 1 Post
Have done a few of these engines in work.With an engine crane the lump will come out the top with gearbox attached with ease without the need to remove the subframe
Currently in cph1984's garage:
2001 VW Golf TDi
cph1984 is offline   Reply With Quote
Old 8th February 2008   #4
clioeagle
clioeagle is
has no status.
Junior Member
Threadstarter
Thanks guys. sounds hopeful.
The last water cooled engine/box combos I took out was an HA Viva and Austin Maxi, which dates me. Things were a bit easier then, there seemed so much space in the engine bay. I have an old Beetle project now but that is almost just a couple of spanners and a trolley jack during the TV ads!.
1997 clio rt 1.2
Reply
Tags
clio, engine, removal
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
