Inputting Radio codes - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 27th May 2008   #1
ZARGON
ZARGON is
has no status.
Junior Member
ZARGON's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Unhappy Inputting Radio codes
Hi Guys need a bit of advice please, Ihave just installed a new radio into my clio mk1.....I know it works ok but i cannot get my stalk control to work when inputting radio codes, can input manually on radio but dont know what to do to save code manually....Can anyone help please.
thanks in advance
Currently in ZARGON's garage:
renault clio rt auto
ZARGON is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by ZARGON
Clio rt 1.4 Auto Altenator Engines chris m 1 741 2nd February 2009 07:33 PM
Registration plates Bodywork ottoman 7 1399 4th September 2008 05:27 PM
Inputting Radio codes Electronics paula138 6 1511 27th May 2008 06:52 PM
Renault Clio 1 - Fuel Gauge Problem Electronics madnoel10 6 3812 29th April 2008 05:31 PM
Renault Clio 1 - Immobilser Problems Electronics madnoel10 12 2204 2nd April 2008 08:24 AM
Sponsored Links
Advertisement
Old 27th May 2008   #2
Getafix
Getafix is
has no status.
Platinum member
Getafix's Avatar
Hi ZARGON
Try this:-
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " ¬ " On The Stalk Control To Enter
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " ¬ " Until A Beep Is Heard
And the Radio will then Turn On
Hope it helps.
Currently in Getafix's garage:
clean and shiny Scenic (and a Fiat Campervan).
Getafix is offline   Reply With Quote Quick reply to this message
Old 27th May 2008   #3
ZARGON
ZARGON is
has no status.
Junior Member
Threadstarter
ZARGON's Avatar
stalk
cant get anything from stalk end ,,,only manual input on radio.
Old 27th May 2008   #4
Getafix
Getafix is
has no status.
Platinum member
Getafix's Avatar
Hi ZARGON
The plot thickens.
If the dislpay is working then the fault could be the connector behind the display that feeds the remote stalk.
Old 27th May 2008   #5
ZARGON
ZARGON is
has no status.
Junior Member
Threadstarter
ZARGON's Avatar
ok will check the stalk connections out again........they were working fine on the old radio , just dont see why the arent working on the new ...same make and model just new.
Reply
Tags
codes, inputting, radio
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
