clio 1.5L diesel fuel pressure regulator location - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 8th August 2008   #1
aatomik
aatomik is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have problems with starting 2006 1.5 dci 50kw clio engine, so I checked the ECU with my diagnostic tool. There I found a trouble code "P0089 fuel pressure 1 regulator performance".
Though, I'm not exactly sure where it is and how should it look like. Could some of you nice folks here help me out a bit and give me some pointers where to start at?
aatomik is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by aatomik
clio 1.5L diesel fuel pressure regulator location Engines motoaude 8 20763 8th August 2008 11:04 AM
Sponsored Links
Advertisement
Old 8th August 2008   #2
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Nominated 2 Times in 8 Posts
Nominated TOTW/F/M Award(s): 4
On the front of the engine follow the pipes from
the injectors you will see a flat round thing thats
the common rail, I think but not 100% that the pressure
regulator or at least the sensor for it is fitted in the
lower half, first thing I would do is check that all
the electrical connections to it and the pump are
clean and tight.
Currently in Ralph's garage:
Clio 15 DCi 80, Motomorini 3 1/2, Yamaha MT-07, LMS 5MT 3 1/2 inch Gauge.
Ralph is online now   Reply With Quote Quick reply to this message
Old 8th August 2008   #3
aatomik
aatomik is
has no status.
Junior Member
Threadstarter
Thanks for a quick reply I followed your advice and found something like this:
Is this the right part? It has an electrical connector in the lower half as well.
I have another crashed clio as donor car, where I can take some parts when necessary, but I just want to be sure where the problem lies, before changing anything.
Old 8th August 2008   #4
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Yes the sensor is the thing on the bottom with
wire going to it, at least I think it is, the regulator
again I think is in the pump it's self, be very careful
when working on this as the pressure is very high,
give it time to drop if you have had it running.
Old 8th August 2008   #5
Gogslad
Gogslad is
has no status.
Diamond member
Gogslad's Avatar
Nominated 0 Times in 1 Post
Nominated TOTW/F/M Award(s): 2
fuel pressure sensor is on the fuel rail at front of engine, IMV valve (pressure regulator) is on the back of the pump, (brown connector)both are pretty reliable, more likely to be a faulty injector or even fuel pump, check the return flow from the injectors by removing the return pipes and plug them, fit clear pipes to the injectors, something like washer piping, run the engine for a short period, I cant remember how long exactly but around 10 secs, see how much fuel is in the clear pipes, if the injector(s) is faulty it will show up as lots of fuel when compared to the rest, or there may be very little return flow, this also could indicate a fault, worth while removing the fuel filter also and drain it into a clear tub after a shake, look for metal filings through the fuel, if there is more than about 1 cm sq then the pump is breaking up, unfortunatley this means replacing the entire fuel system as the metal will damage any new components fitted.
G.
__________________
Currently in Gogslad's garage:
Koleos, RR1 Fireblade, RRW Fireblade, CZ 125.
Gogslad is offline   Reply With Quote Quick reply to this message
Reply
Tags
15l, clio, diesel, fuel, location, pressure, regulator
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
