How To Repair Laguna 2 Heater Blower Not Working On Speeds 1,2 And 3. - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Miscellaneous
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Miscellaneous
Reply
Thread Tools Search this Thread Display Modes
Old 9th August 2008   #1
5th wheel
5th wheel is
has no status.
Platinum member
5th wheel's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My Mood: Fine
the ballast resistor is located behind the blower motor ,it can be tricky to access,as i am 6ft 2" the easiest way for me was to lower the passenger seat backrest down and get your head into the footwell.the wiring block is also on a short loom with a white square block one end, and a black rounded ends about 3" the other end. which has 2 5.5mm bolt screws holding it in place in the blower motor,remove the loom from both connections.on one side of the board is a saftey wire in the shape of a letter (W) if this has come away from soldering joint your blowers will not work,if the card has burn't out reno charge £52.00 for card and £34 52 for loom. good look.
Click image for larger version
ID:	6212   Click image for larger version
__________________
ONCE A BLUE ALWAYS A Blue.
A FRIEND IN NEED~~~IS A PEST.GET RID OF HIM
Currently in 5th wheel's garage:
56 focus c.max 1.6 zetec / 07 6x2 440A M.A.N
5th wheel is offline   Reply With Quote
5 Lastest Threads by 5th wheel
woman in court Jokes & funny stuff martyboi 2 1080 21st March 2010 11:18 AM
pet shop Jokes & funny stuff Donald 1 878 5th February 2010 09:17 PM
cage fight Jokes & funny stuff scatz 1 1055 31st January 2010 07:50 PM
do not reply General Chat hondo 4 801 25th December 2009 12:15 PM
gone but not forgotton General Chat Mike11 10 1420 7th November 2009 08:01 PM
Sponsored Links
Advertisement
Old 10th August 2008   #2
ottoman
ottoman is
has no status.
Platinum member
Nominated 1 Time in 1 Post
Nice one 5th
ottoman is offline   Reply With Quote
Old 3rd January 2009   #3
petercee
petercee is
has no status.
Diamond member
blower fan motor
great pictures, can anyone tell me if they have tried to get these fixed by a technician that repairs circuit boards, could be cheaper than a new one. my scenic has this problem its a scenic 1, 1999 model with aircon, does anyone have knowledge of where i locate it on the scenic
Currently in petercee's garage:
1998 scenic rxe
petercee is offline   Reply With Quote
Old 6th June 2009   #4
sheriffdude
sheriffdude is
has no status.
Member
My Mood: Angry
Send a message via MSN to sheriffdude
hi have the same problem but my fan just stoped dead have located ballast resistor and is same as urs what do you mean by the loom ..i cant tell if the resistor is broken or not ..i have ben told it can be the heater switch ..its self if so i dont know how to get to that ..there were loads of leaves in the pollen filter so have cleaned that ..so i think its off to maplin to see if they can test it ..
Currently in sheriffdude's garage:
laguna 2
sheriffdude is offline   Reply With Quote
Old 6th June 2009   #5
wozz
wozz is
has no status.
Member
My Mood: Grumpy
Ballast resistor
Quote:
Originally Posted by sheriffdude View Post
have located ballast resistor and is same as urs what do you mean by the loom ..i cant tell if the resistor is broken or not ......so i think its off to maplin to see if they can test it ..
The Ballast resistor is just a low resistance in series with the motor. You can tell if it's working if you have a multimeter.
I dont have the board in my hand so my description of how to measure it is a guide.
Either end of the long curly track on the green board will probably go to the pins on the connector, just trace it through visually. The little W thing is prob a safety fuse in series with the long curly bit, (I'm guessing please see caveat at end). When you've found the pins it goes to, with the multimeter switched to resistance or ohms ***937; touch the probes of the meter to each other and the meter should read around zero ish. Now put the probes on the pins connected to the track and you should get a reading of a few ohms, I don't know the exact figure but it doesn't matter, could be anywhere between A fraction of ***937; and 20***937;. If you get any low resistance reading and the continuity of the track is ok then its prob working ok, if the meter reads open circuit or very high resistance it's not ok. Get someone who knows how to use a meter if you aren't sure.
There are safety implications in replacing the sections of curly bit with (wirewound) resistors, you can't do that unless
1) the W safety link is intact, and 2)the wattage rating of the resistors is sufficient as they will get hot
It's probable that if it has failed either the track will be cracked near the connector or the safety W will be burnt out. (I'm only guessing that its a safety W, it might just be another low resistance to control the speed?)
hope that helps a little.
woz
Currently in wozz's garage:
2000 Clio 1.4 8v sport
wozz is offline   Reply With Quote
Reply
Tags
blower, heater, laguna, repair, speeds, working
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
