handbrake adjustment.Where is it!!! - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Wheels & tyres
Reply
Thread Tools Display Modes
Old 1st October 2008   #1
xdaman
xdaman is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Have spent ages looking for adjusting screw for my Kangoo.
Someone else asked but no reply.
Can you help please?
Currently in xdaman's garage:
Renault Kangoo
xdaman is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by xdaman
Kangoo Air Bag/Serv light.Done usual things! Electronics xdaman 2 218 22nd July 2015 03:27 PM
Kangoo. No electrics,then slowly restores power? Electronics xdaman 2 362 25th January 2015 04:53 PM
No more hair to pull out!! Engines xdaman 7 1822 31st July 2010 08:53 PM
kangoo fuel pump not working! Engines xdaman 5 4886 1st March 2010 07:58 PM
handbrake adjustment.Where is it!!! Wheels & tyres tolsen 4 11448 1st October 2008 05:30 PM
Sponsored Links
Advertisement
Old 1st October 2008   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
As a general rule on most cars the handbrake adjustment is either around the bottom of the handbrake lever or along the cable underneath - it's where I always start to look - in my Lag it is at the bottom of the centre console box.
In all honesty I don't know exactly where it may be on the Kangoo but it may be worth having a look in these areas.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 1st October 2008   #3
xdaman
xdaman is
has no status.
Member
Threadstarter
Yes that's what I thought.
I have a suspicion it could be under heat shield, below handbrake.
Reluctant to remove since will start to rattle most probably.
Thanks.
Renault Kangoo
Old 2nd October 2008   #4
madnoel10
madnoel10 is
has no status.
Technical Supremo
Hi Xdaman - does your car have disk or drum rear brakes and why do you need to get at the adjustment anyway
Honda Civic 1.4l
Old 3rd October 2008   #5
tolsen
tolsen is
has no status.
Banned User
Nominated 0 Times in 9 Posts
Nominated TOTW/F/M Award(s): 3
Handbrake cable adjustment nuts are above the heat shield below the Kangoo handbrake lever. You must ensure the automatic take up mechanism on the drum brakes is OK before adjusting the cable. For rear disc brakes, confirm the levers on rear calipers are not seized. I fitted grease nipples on mine. Injected red rubber grease to avoid damage to seals. Use large flat washers when you refit the heat shield. Sticking a vibration dampening sheet to the back side of heat shield also strongly recommended. Buy Peter Russek's Pocket Vehicle Manual for the Kangoo. Covers 1.5 & 1.9 diesel from 2001 to 2006 including Trekka and Nissan Kubistar.
Currently in tolsen's garage:
Trekka 1.9 DCI, Smart Cabrio Cdi (65 - 85 MPG) & Ford Transit 2.2 Duratorq TDCi
tolsen is offline   Reply With Quote Quick reply to this message
Reply
Tags
adjustmentwhere, handbrake
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
