Megane II 1.5 dCi Heater Fan 1,2,& 3 speed not working - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Heating & cooling
Notices
Heating & cooling A place to discuss heating, air-con etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Heating & cooling
Reply
Thread Tools Search this Thread Display Modes
Old 7th November 2008   #1
zamgod
zamgod is
has no status.
Junior Member
zamgod's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My heater blower has stopped working on settings 1, 2 and 3 but it works fine on setting 4. The problem apparently, see Laguna thread (Renault Laguna I - Phase 2 - Heating and Cooling - Heater Fan 1,2,& 3 speed not working + FIX), is the heater resistor (thermal fuse).
Unlike the Laguna, the heater blower on the Megane II is behind the centre console and pretty awkward to get at. Although I haven't fitted a new thermal fuse yet, don't have one, I did attempt to access it. A sort of “dry run” to see if I could do it and to see what the little blighter looks like. I found that, unless you're a contortionist, it's easier to remove; the small panel at the right of the passenger footwell, the glove box compartment and also the side vent air duct.
The following photo shows the little blighter and because it’s nigh on impossible to disconnect the blower feed from behind the cetre console, the “fix” will have to be done insitu.
Hope this helps Megane owners.
Click image for larger version
Currently in zamgod's garage:
2004 Renault Megane 1.5dCi 101 bhp
zamgod is offline   Reply With Quote
5 Lastest Threads by zamgod
Megane II 1.5 dCi Heater Fan 1,2,& 3 speed not... Heating & cooling david40buts 20 22664 7th November 2008 06:12 AM
Sponsored Links
Advertisement
Old 7th November 2008   #2
ottoman
ottoman is
has no status.
Platinum member
Nominated 1 Time in 1 Post
Thanks for the info Zamgod
ottoman is offline   Reply With Quote
Old 14th November 2008   #3
zamgod
zamgod is
has no status.
Junior Member
Threadstarter
zamgod's Avatar
Fan Fix
At long last I've managed to procure a thermal fuse (110degC) and fitted it. Instead of soldering the connections I used connectors obtained from a company on ebay. The URL and item number is:
MICROTEMP THERMAL FUSE CONNECTOR / TERMINAL
Item number: 220170761846
http://cgi.ebay.co.uk/MICROTEMP-THER...742.m153.l1262
My heater is working properly now, all speeds accounted for!
The pic shows the connection, it's a wee bit out of focus, a sign of old age ;o]
Old 28th January 2009   #4
TM88
TM88 is
has no status.
Junior Member
Glovebox removal
Hi there, could you give us a few pointers on how to remove the glovebox so i can change my thermal fuse for my heaters. Thanks T.
Cancel this i've managed to work it out.
Currently in TM88's garage:
2003 megane 1.5 dci
TM88 is offline   Reply With Quote
Old 5th February 2009   #5
steve1975l
steve1975l is
has no status.
Member
steve1975l's Avatar
Thanks for the picture. I have the joy of fixing this next job as speed 4 has gone.
I am a RF Engineer and we use resistors to drop the rail voltage to the fans and they often go open circuit too.
Anyone need any pics?
steve1975l is offline   Reply With Quote
Reply
Tags
dci, fan, heater, megane, speed, working
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
