Engine management light flashing - losing power - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 7th December 2008   #1
gerrard_d
gerrard_d is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi, I have been driving my 2005 1.6 megane privilege for about 8 months now without any problems. I did have a couple of issues where the car would not start first time in the morning, but after a couple of attempts it was ok, and this was intermittent.
Today I was driving along a started to lose power and the engine management light started flashing. Can anyone give me some advice on what this might be?
I've read around and found it could be the engine coils, are these expensive to replace?
I'm going to take it to the garage tomorrow but hope someone may be able to give me a heads up as to the problem!?
Many thanks in advance!
Dan
Currently in gerrard_d's garage:
2005 Renault Megane 1.6 Privilege
gerrard_d is offline   Reply With Quote
5 Lastest Threads by gerrard_d
Engine management light flashing - losing power Engines gerrard_d 15 8524 7th December 2008 04:47 PM
Hi Welcome to RenaultForums Mike11 4 297 7th December 2008 04:41 PM
Sponsored Links
Advertisement
Old 7th December 2008   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 43 Times in 42 Posts
Nominated TOTW/F/M Award(s): 19
My Mood: Cheerful
The two most common causes of poor running on Renault engines seems to be either duff coils or TDC sensors so it may well be worth getting those checked out first.
Keep us posted
Currently in madnoel10's garage:
1994 Clio diesel and a Honda Civic 1.4l
madnoel10 is offline   Reply With Quote
Old 7th December 2008   #3
gerrard_d
gerrard_d is
has no status.
Junior Member
Threadstarter
Quote:
Keep us posted
Thanks for the response, how much would I be looking at to replace either of these from somewhere like nationwide autocenters?
Old 7th December 2008   #4
madnoel10
madnoel10 is
has no status.
Technical Supremo
My Mood: Cheerful
Depending on the quality each coil could start at around £15 plus each plus labour. If you find out its a coil problem try to identify which ones are duff and replace only them. Generally it only takes around 10 minutes or so for each coil and if you have the tools you could attempt it yourself. But find out the exact problem first
Old 7th December 2008   #5
gerrard_d
gerrard_d is
has no status.
Junior Member
Threadstarter
Depending on the quality each coil could start at around £25 each plus labour. If you find out its a coil problem try to identify which ones are duff and replace only them. Generally it only takes around 10 minutes or so for each coil and if you have the tools you could attempt it yourself. But find out the exact problem first
Absolutely no chance of me doing it myself!! I'd end up doing more damage!!!
I've been told its best to change them all, it this true, if so i'd be looking at £150ish??
Do these affect fuel consumption as well?
Reply
Tags
engine, flashing, light, losing, management, power
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
