Changing a battery on a Renault Scenic II - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 3rd January 2009   #1
1965nick
1965nick is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi I have a 1.6 vvt privilige Renault Scenic 04 plate. How do I change the battery? Is it a case of just removing the terminals and connecting in the new battery, or is there more involved?
Thanks for any help, anyone can gice.
Currently in 1965nick's garage:
2004 Renault Scenic II 1.6VVT Privilige
1965nick is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by 1965nick
Changing rear ABS sensor Scenic II Brakes/Hubs madnoel10 1 2589 4th February 2013 11:51 AM
Scenic II 1.6 clutch failure and cam belt failure Engines madnoel10 1 862 20th September 2012 12:56 PM
Scenic II ABS sensor fault Brakes/Hubs barachello 6 6448 13th November 2011 09:23 PM
|Scenic II heater blower problem and faulty dash! Electronics 5 2988 13th November 2011 05:02 PM
Windcsreen wipers on Scenic II Electronics jasont 6 1665 4th February 2009 12:36 PM
Sponsored Links
Advertisement
Old 3rd January 2009   #2
Asterix
Asterix is
has no status.
Platinum member
Typing Test Champion
Asterix's Avatar
It is recommended that you leave the sidelights switched on during the changeover, this will minimise any power surge from the new battery, also make sure that you know the code for the radio, as you will have to input this after changing battery.
__________________
Life is too short...laugh and enjoy it while you are able to
'24 hours in a day, 24 beers in a case. Coincidence? I Think not !!
Currently in Asterix's garage:
Renault Megane Scenic II 06 1.5dci Oasis in Eclipse Grey Metallic but it is not in a garage
Asterix is offline   Reply With Quote Quick reply to this message
Old 3rd January 2009   #3
stef123
stef123 is
Platinum member
stef123's Avatar
as asterix said. also disconnect the negative terminal first. connect the negative last when reconnecting.
Currently in stef123's garage:
2006 Ford Mondeo ST TDCI
stef123 is offline   Reply With Quote Quick reply to this message
Old 3rd January 2009   #4
DerryUK
DerryUK is
has no status.
Member
<leave the sidelights switched on during the changeover>
Ignore that, I think Asterix is still in 'happy' mode from the seasonal break <s>.
Derry.
Currently in DerryUK's garage:
2004 Scenic Expression 1.6
DerryUK is offline   Reply With Quote Quick reply to this message
Old 3rd January 2009   #5
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Nominated 2 Times in 8 Posts
Nominated TOTW/F/M Award(s): 4
Our local car shop uses a small 12v battery connected by
crocodile clips to keep the car powered up when changing
batteries so they dont loose any codes.
__________________
Ralph's 4th law of motion states that any dropped object will immediately hide under a larger object.
If you find a fix for your problem please let us know it will help others.
Ralph Nr Fleetwood NW UK.
Currently in Ralph's garage:
Clio 15 DCi 80, Motomorini 3 1/2, Yamaha MT-07, LMS 5MT 3 1/2 inch Gauge.
Ralph is offline   Reply With Quote Quick reply to this message
Reply
Tags
battery, changing, renault, scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
