changing glow plugs on a 1.9dci scenic - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 1st February 2009   #1
keithdon
keithdon is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi Can any one tell me if it is easy to change the glow plugs on a renault scenic. It is the access i am wondering about. eg how do you get to them. Thanks
keithdon is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by keithdon
scenic top cover removal to get at glow plugs Engines payne3400 2 2459 10th February 2009 07:40 PM
changing glow plugs on a 1.9dci scenic Engines Prickleypear 9 26020 1st February 2009 03:04 PM
Sponsored Links
Advertisement
Old 1st February 2009   #2
ottoman
ottoman is
has no status.
Platinum member
Nominated 0 Times in 1 Post
Hello & Welcome to the Forums Keith
Hopefully one of our more technical Members will offer some advice
ottoman is offline   Reply With Quote Quick reply to this message
Old 1st February 2009   #3
levski
levski is
has no status.
Diamond member
levski's Avatar
Glowplugs 1.9dCi
I have just changed all 4 glowplugs on my Megane 1.9dCi and although its a bit of a fiddly job, its not too difficult.
I'm not too sure about the access on a Scenic but on the Megane, you need to remove the large plastic cover which sits on the top of the engine - just remove the three bolts which sit underneath small plastic covers. Once the cover is off you can access the glowplugs directly.
See attached photo, where I have indicated one of the white glowplug leads with a yellow arrow.
Click image for larger version
As I said it is a bit fiddly but one thing I should add is that I did end up buying an addition to my toolbox - a set of glow plug sockets. (£20)
It's just a case of removing the glowplug leads - on the Megane they pull off, some are connected using a nut/washer arrangement.
Then (as I said using the glow plug socket set) remove each one in turn and replace with a new one.
Let me know if this is of any use to you and I'll try and help some more.
Levski.
Currently in levski's garage:
2001 Renault Megane 1.9dCi
levski is offline   Reply With Quote Quick reply to this message
Old 4th February 2009   #4
keithdon
keithdon is
has no status.
Junior Member
Threadstarter
Hi Thanks for the reply. I will try to do them this weekend and let you know how i get on. Regards
Old 9th February 2009   #5
keithdon
keithdon is
has no status.
Junior Member
Threadstarter
Still have not done the job. I could not get the top cover off. it was sticking under thewater piping.
Reply
Tags
19dci, changing, glow, plugs, scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
