Air Bag warning light - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 8th February 2009   #1
john griffiths
john griffiths is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi All
My 02 Laguna 2 has done some strange things in the past but this is a new one. The air bag light come on only when the vehicle is accelerating, let off the gas the light goes out, now the thing i find curious, if there is a fault, even if its an intermitten fault should the air bag warning light should come on and stay on and log a code in the SRS control module like ever other car on the road, have been a mechanic all my working life. I have had the usual fault of the wiring under the seat on the OS,the air bag light come on and stayed on, in the end i had to cut the connector out and simply soilder the wires together, this fixed the fault and have access to a code reader but only at work. So if any body should know if an intermittent fault will cause the warning light to come on intermittently would be a big help. Thanks
Currently in john griffiths's garage:
Renault Laguna Coupe 2.0 DCI Tom Tom and Renault Laguna 2 2.0 dCi 2007MY
john griffiths is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by john griffiths
Air Bag warning light Electronics skymax 7 5241 8th February 2009 12:47 PM
Sponsored Links
Advertisement
Old 8th February 2009   #2
mister_cee333
mister_cee333 is
has no status.
Diamond member
I worked on a Rover a while ago in which some wiring under the carpets had been disconnected and the airbag light was on. When the wiring was re-connected the light went out. Perhaps you've got a loose wire somewhere and the system is self diagnosing?
Currently in mister_cee333's garage:
Toyota Avensis 1.8. Formerly Jaguar X Type Sport d 2005. Formerly 2001 Laguna 2 1.9 dCi
mister_cee333 is offline   Reply With Quote Quick reply to this message
Old 8th February 2009   #3
john griffiths
john griffiths is
has no status.
Junior Member
Threadstarter
I worked for Volvo for over 20 years up until recently where I became a college lecturer, teaching motor vehicle, on all the Volvos it would log a code and leave the light on,I think this is true of the German cars and the Fords,all i can do is check it out as soon as possible,it just seems a bit mad, after reading some other Air Bag light on threads, if you valet your car like i did yesterday and move the seat there a chance you will bring the air bag warning light on! i have two Laguna a 02 and 07 model the new one hasnt give a monents trouble and still pleased with both cars, and now looking for a replacement for the 02 car, thinking may be a Megane or Clio sports.
Old 11th February 2009   #4
john griffiths
john griffiths is
has no status.
Junior Member
Threadstarter
I think i have got to the bottom of it, the only code in the air bag control module was a CAN net work code fault, communication fault, the only thing i can put it down to, is when the car was first started it laboured to start, the battery was a little flat but enough to start the engine,as the car had been stood for some time. May be the low battery voltage caused this fault, since the battery has been fully charged its been ok, i know it sounds silly but CAN net works are very sensitive to voltage and i think that was the fault, nothing more than low battery voltage. it may be some use to any one with a simular problem.
Old 17th July 2013   #5
lihpkralc
lihpkralc is
has no status.
Junior Member
Re: Air Bag warning light
Was the battery the answer? I have been experiencing the same fault over the last few months. When I accelerate the airbag light comes on and if I keep on accelerating it will go out? Was thinking that as I had the headlights on that the voltage might be down enough so that when I put foot down on the gas a momentary drop in voltage due to load from various areas could cause the problem. After accelerating a bit the voltage will increase and then the airbag light will go out? sound like a good theory? Have checked battery and seems to be fine. Starts always first pop and no reason otherwise to doubt battery condition.
Currently in lihpkralc's garage:
Renault 17 Gordini 1976, 2002 V6 Laguna Privilege Wagon
lihpkralc is offline   Reply With Quote Quick reply to this message
Reply
Tags
air, bag, light, warning
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
