Scenic II, how to remove all dashboard cover - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Interiors
Notices
Interiors Discuss leaks, seats, carpets etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Interiors
Reply
Thread Tools Display Modes
Old 10th February 2009   #1
omrigez
omrigez is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I'm trying to remove my scenic II dashboard cover. Not only the center part or upper (I seen previous threads about it) but the dashboard cover itself. I'm trying to get to the air circulation toggle mechanism which doesn't work and is located somewhere behind it.
Does someone have experience with that and can explain how to do it??
omrigez is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by omrigez
scenic II vibrations when engine (petrol 2L) is... Engines omrigez 15 3945 17th February 2009 10:58 AM
Scenic II, how to remove all dashboard cover Interiors chestnut2000 2 10138 10th February 2009 01:29 PM
Scenic II air circulating mechanism probelm Heating & cooling jonaskuling 2 1151 9th February 2009 08:07 PM
Sponsored Links
Advertisement
Old 10th February 2009   #2
DJC013
DJC013 is
Mellow !!
Diamond member
DJC013's Avatar
Hello, i remember a post on here recently, i think first you unclip the gear lever gaitor, then remove the trim its fixed to, which reveals screws which hold the heater panel trim on. I think you also have to remove the stereo, hope this helps, regards Damian.
Currently in DJC013's garage:
2004 Scenic II 1.9 dCi Dynamique 6 Speed Black (VF1 JMRG) F9Q 812 NDO
DJC013 is offline   Reply With Quote Quick reply to this message
Old 9th July 2010   #3
chestnut2000
chestnut2000 is
has no status.
Junior Member
Re: Scenic II, how to remove all dashboard cover
Could I enquire if you found the answer to this question. I have a similar requirement to get into the electronic control unit for the blower speed. Ulike the resistor based pack it seems impossible to reach from the side of the instrument cluster ?
Unless anyone knows better, in which case do please share this info.
chestnut2000 is offline   Reply With Quote Quick reply to this message
Reply
Tags
cover, dashboard, remove, scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
