Clio 1.5 dCi timing belt change - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 17th March 2009   #1
anthonyjayw
anthonyjayw is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have decided to take the plunge and change the timing belt on my car myself. I have all the necessary tools and will be changing the timing belt and tensioner, the water pump, the alternator belt and tensioner as i've been advised that its best to do all these jobs at the same time.
Are there any common pitfalls i need to be aware of before i start the job and is it best left to the guys in the workshop or provided you take your time is it a fairly straight forward task?
What is the best type of thread locking glue to use on the studs etc? The old trusty haynes manual keeps referring to putting threadlock on here there and almost everywhere!
Also removing the stud on the crankshaft pulley, are they normally very tight and spin the engine as you try to slacken it off? Does it need a sharp wallop with a hammer to loosen it?
When replacing the water pump, does the gasket go back dry or with sealer on it?
Any advice and tips on how to best proceed would be really helpful.
Many Thanks
Anthony
Currently in anthonyjayw's garage:
2004 Renault Clio dCi 80 BHP
anthonyjayw is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by anthonyjayw
Clio dCi hesitant/smokey Engines glynn johns 8 3847 17th March 2009 11:49 PM
Clio 1.5 dCi timing belt change Engines justy22 5 28402 17th March 2009 11:34 PM
Clio tyres - guidance please!! Wheels & tyres davesss 3 1460 24th January 2009 08:21 PM
Front coil spring broken! Steering and Suspension madnoel10 15 40399 9th December 2008 08:39 PM
Renault Cio - Cleaning Seat Belts Interiors 2 1202 10th September 2008 09:29 PM
Sponsored Links
Advertisement
Old 22nd March 2009   #2
Pat.w
Pat.w is
has no status.
Edit
Posts: n/a
Loctite make a good range of threadlock adhesives
You can buy it online
Old 22nd March 2009   #3
Mickb
Mickb is
doing anything except what he should be doing!!.
Member
Mickb's Avatar
Wish I had the bottle to do it myself.
By the way my local Renault dealer only charged me £250 to change the belt on my Clio 1.5 dci 80 around 18 months ago. The local independents were asking around £700.
I am not trying to put you off.........
Currently in Mickb's garage:
2006 Renault Laguna II 1.9dCi & 2005 Renault Megane II 1.9dCi
Mickb is offline   Reply With Quote Quick reply to this message
Old 28th March 2009   #4
anthonyjayw
anthonyjayw is
has no status.
Member
Threadstarter
where is your dealer based?
my local one wanted a fair bit more than that!!
Old 29th March 2009   #5
Mickb
Mickb is
Member
Mickb's Avatar
The dealer I used is in Newcastle Upon Tyne, on Scotswood Road. They are a Renault Main dealer.
I only happened to ask how much it was when I purchased my wife's Megane and was surprised.
They had the job done on a morning.
Reply
Tags
belt, change, clio, dci, timing
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
