megane 1.5 dci - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
megane 1.5 dci
Engines
Reply
Thread Tools Display Modes
Old 20th March 2009   #1
chydrema
chydrema is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
megane 1.5 dci
Hi i've looked around and whilst there are similar threads with this problem they dont quite fit for me, so sorry if this is repeating old ground.
My problem is with my '05 megane 1.5 dci, recently the toxic fume filter lamp has come on and stayed on, however, neither at the time nor since has the performance of the car been affected, no undue smoke, fuel economy is unchanged, engine runs and idles fine, so what should i be looking at as a fault?
thanks
chy
Currently in chydrema's garage:
2005 megane 1.5 dci sport tourer
chydrema is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by chydrema
megane 1.5 dci Engines Taipan 17 3128 20th March 2009 01:57 AM
Sponsored Links
Advertisement
Old 24th March 2009   #2
chydrema
chydrema is
has no status.
Junior Member
Threadstarter
Red face
please, someone.
Old 29th March 2009   #3
SAILORVET
SAILORVET is
has no status.
Member
Don't panic too much. Has the car been reluctant to start sometimes? I'm asking this because if the engine tries to fire you will get excess unburnt fuel going into the exhaust cat, and this will give you that warning. If that's the case, then it'll probably burn itself away after a while and the lamp will go out. Another place to check however is the sensor on the exhaust and if I remember right it's called a Lambda sensor, try disconnecting this give the contacts a good clean and re-fit. Good luck.
Currently in SAILORVET's garage:
2004 Clio 1.5 dci Authentique, Yamaha R1 52 plate
SAILORVET is offline   Reply With Quote Quick reply to this message
Old 30th April 2009   #4
dieselauto
dieselauto is
has no status.
Junior Member
Hello, an excellent forum with lots of help. Was there any progress or resolution in this case, I have exactly the same situation with my 2004 1.5dci (Auto) Megane. The light has been on for about a month now but absolutely no running issues or loss in performance, I have cleaned the EGR valve, removed the battery to see if it would clear to no avail. Haven't investigated the exhaust sensor yet, anyone else had and cured the problem?, cheers
Currently in dieselauto's garage:
2004 Megane 1.5dci Auto
dieselauto is offline   Reply With Quote Quick reply to this message
Old 15th May 2009   #5
dieselauto
dieselauto is
has no status.
Junior Member
Hello, just to update anyone that is searching this thread or has the same problem. I have had the problem for about 2 months now and tried the EGR clean, glow plug check, cleaned every pipe / hose filter I could find plus disconnected the battery to see if it would force a re-set but to no avail. Still no apparent running problems. Just about to throw myself and my wallet at the mercy of a dealer.
Yesterday, started the car at the end of the day as usual, warning lights gone, turned off and re-started a few times and still no warning so presume all resolved, fingers crossed.
Whilst I'm happy it has gone would have liked to have known what or why! Bide my time until the next helpful light appears!
Reply
Tags
dci, megane
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
