Megane II cold start problem - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 16th April 2009   #1
petta
petta is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hello!
I have a Renault Megane II 2005 1,6 16v. My problem appeared a couple of weeks ago when the car didn´t start on the first try as i used to. when I press the startbutton now it takes up 3-4 tries before it starts. The start engine works, it fires, but won´t turn over. The start problem is only when the engine is cold. If I were to drive the car for a while, stop and turn it of/on again it would start on the first try after pressing the start button. The cold start problem also appears when I´m driving. when the engine is cold, the idle is moving up and down, just a little bit, and when I throttle, the engine "jumps" a little bit. The problem disapears as soon as the engine gets warm and then it works perfectly.
Do you have any clue what the problem might be?
best regards,
Petter
petta is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by petta
Megane II cold start problem Engines j1mmy1985 3 3648 16th April 2009 03:55 PM
Sponsored Links
Advertisement
Old 17th March 2011   #2
j1mmy1985
j1mmy1985 is
has no status.
Junior Member
Re: Megane II cold start problem
hello petta did you get to the bottom of your problem as I am having very similar issues.
thanks James
P.S. heater plugs are ok and I have cleaned the TDC sensor
j1mmy1985 is offline   Reply With Quote Quick reply to this message
Old 17th March 2011   #3
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Hi Jimmy - welcome to the forum.
As you mention your engine has heater plugs I take the engine is a diesel. The post by Petta refers to a petrol engine.
But if you are having starting difficulties from cold but all is OK when the engine is warm it may be worth checking the engine coolant temp sensor/s. If faulty the ECU will think the engine is always warm and therefore not adjust fuel and injection timing to suit cold starting.
No gaurantee that is you problem but it may be worth checking if only to rule it out as a possibility.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 19th March 2011   #4
j1mmy1985
j1mmy1985 is
has no status.
Junior Member
Hi madnoel10
TBH i have read that many forums that i didn't realize this was about a petrol lol
have you any idea where the coolant temp sensor is located on a 1.5 dci
thanks James
Reply
Tags
cold, megane, problem, start
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
