Need to reset ECU after new coils? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 22nd April 2009   #1
bigbruggsy
bigbruggsy is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi i have a 2001 renault scenic 2l automatic, which has been having problems with power loss and surging, first i thought it was the gearbox as it threw up a gearbox warning light on the dash. I took it to a mechanic and he checked the fault codes stored on the computer and found the car had a "miss" firing sometimes only on 2 of the cylinders. So i replaced all the ignition coils and spark plugs. The car feels a bit better but not back to the way it was before this problem. do i have to reset the ECU to completely fix the problem? or is there something else wrong?
Currently in bigbruggsy's garage:
Renault Scenic 2001 model
bigbruggsy is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by bigbruggsy
Scenic fault codes, electrical problems,... Engines Belindz 27 42481 16th June 2009 09:26 AM
Need to reset ECU after new coils? Engines Donald 1 10496 22nd April 2009 01:19 AM
Scenic sudden loss of power Engines bigbruggsy 4 4721 21st March 2009 05:49 AM
Scenic surging then hesitant, lack of power Engines bigbruggsy 16 6544 16th February 2009 08:49 PM
Sponsored Links
Advertisement
Old 22nd April 2009   #2
Donald
Donald is
mad
Platinum member
Technical Supremo
Fishing the Sea Champion
Donald's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 11
Hi i had much the same problem last year with my Espace missing and i changed the plugs and all the pencil coils and i have to say mines was not reset not that i recall?? hope that helps a little,
oh if it helps when mines through the wobbler it did not give me any lights on the dash it was my friend at a local independent that said he was sure it was a coil playing up and it was arcing through the rubber so i told him to change them all along with the plugs and it run well ever since,sorry if this not helping that much so if i had to guess i would say you have another problem??
i wonder if its the catalyst or its sensor?? thats just a pure guess though,
Cheers Donald
Currently in Donald's garage:
2005 Mercedes Benz C200 Classic SE Kompresser & 1998 Fiat Cinquecento Fire Sporting,some may say i could do far better?,i say i could do far worse.
Donald is offline   Reply With Quote Quick reply to this message
Reply
Tags
coils, ecu, reset
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
