Trafic power steering pump replacement and steering judder - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Steering and Suspension
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Reply
Thread Tools Display Modes
Old 22nd May 2009   #1
eep803
eep803 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi, I came to pull out of a carpark and my power steering had gone dead. I looked underneath and I was leaking power steering fluid from the end cap of my power steering pump which had popped off just a little. I tried tapping it back in but it was out for a reason.
I have replaced the pump myself as it looked pretty easy (and was) and I'm away from my trusted local garage.
The power steering now works but when I turn the steering wheel when stopped or going very slowly there is ever so slight a judder to the steering wheel. When at speed or not turning the wheel theres nothing at all.
Can you help?
When I put the new pump on all (most) of the fluid had leaked out. I just topped up the reservoir, then turned the engine over and kept topping it up until it was full. I'm wondering if I should bleed it?
Many thanks, Dave
Currently in eep803's garage:
2005 Renault Trafic 100dCi
eep803 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by eep803
Trafic power steering pump replacement and... Steering and Suspension madnoel10 5 16329 22nd May 2009 05:09 PM
Sponsored Links
Advertisement
Old 22nd May 2009   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
The juddering could be air trapped in the system. The recognised method of bleeding is to turn the steerig from lock to lock a number of times with the filler cap removed - just be prepared for some spillage in case a large bubble of air should surface. It may also be prudent to re-check the drive belt in case it is snatching
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 22nd May 2009   #3
eep803
eep803 is
has no status.
Junior Member
Threadstarter
Hi, thanks for the speedy reply.
Firstly I'm pretty happy with the aux belt as last year a garage replaced my alternator but not the belt and two days later the belt snapped, flicked up behind the timing belt and trashed the engine. When I was refitting the belt I checked, rechecked and then checked the belt again. I even turned the engine over manually to check it was running smoot and all seems well.
When I filled the system up I had the wheels off the ground and was repeatedly turning the wheels from lock to lock and the juddering decreased but there is still this residual juddering which is still there.
I'm glad to hear that juddering is a sign of air in the system rather than, say, the rack being faulty. I suppose just a bit more driving and lock to locking and it may work out?
Cheers, Dave
Old 22nd May 2009   #4
madnoel10
madnoel10 is
has no status.
Technical Supremo
See if it settles down. I once had a similar problem on a Vauxhall and it was week or more before it came right
Keep us posted on how it goes
Honda Civic 1.4l
The Following User Says Thank You to madnoel10 For This Useful Post:
Andaru8 (3rd May 2013)
Old 26th May 2009   #5
eep803
eep803 is
has no status.
Junior Member
Threadstarter
Hi, so it looks like the juddering has passed with a week of driving (good call there). But....
Driving on a long journey today there were a couple of times when it felt like the engine was straining and underpowered and after pulling up a long hill there was a definite squeeking sound.
I'm wondering if the new pump is offering a lot of resistance to the aux/alternator belt and maybe causing the engine some extra load. I'd heard that a seized pump could actually stall the engine?!
Is it possible for the hydraulic circuit that the pump drives/pressurises can become blocked thereby giving a load of back resistance to the pump? I wonder if thats what made the original pump blow its end cap off?
Many thanks, Dave
Reply
Tags
judder, power, pump, replacement, steering, trafic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
