Kangoo gear linkage refitting and set up - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 22nd July 2009   #1
madrallysport
madrallysport is
Tortured with dci.
Junior Member
madrallysport's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question Kangoo gear linkage refitting and set up
Guys just replaced the engine in my kangoo van after a timing belt faliure (bought the van like this) removed the gearbox and old engine out the top of the van, assemled engine and box together on the floor then refitted, i've all done except the gear linkage, how to i line it up as i've never really worked much on renaults before, the engine and box are from a 2000 kangoo, 1.9d.
Any help and advice would be great.
Currently in madrallysport's garage:
2003 Kangoo Van
madrallysport is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by madrallysport
Kangoo dci starts some times. Engines TTT 8 1244 1st February 2014 07:05 AM
Kanggo ECU pin outs / wiring diagram Electronics maltech 4 3996 22nd August 2009 12:55 PM
Kangoo gear linkage refitting and set up Engines madrallysport 2 4958 22nd July 2009 01:06 PM
Kangoo Timing belt Faliure Engines madnoel10 2 1097 6th April 2009 01:18 PM
Sponsored Links
Advertisement
Old 22nd July 2009   #2
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Ideally the rod from the gearbox should have been marked before you took it off,or the better thing to do is to remove the rubber cover from the gearbox end of the selector rod and undo that bolt as this means that the adjustment isn't altered.(Hindsight is a wonderful thing I know.)
The easiest way to line the linkage up is to get someone to hold the gearstick in the centre of the neutral position,and then make sure the gearbox is also in neautral and line the end of the bar up to the line that should have been left on the gearbox end rod where it was previously positioned.Do the bolt up in the clamp on the linkage and try all the gears.You may need to further adjust the rod,but it will give you a good starting point.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 22nd July 2009   #3
madrallysport
madrallysport is
Tortured with dci.
Junior Member
Threadstarter
Cheers , i never thought about making til after , i've only ever worked on vauxhalls before and you dont make them, as you pin the lever inside the car and then pin the box, tighten the bolt job done, i was just wondering if this was the case with the kangoo, but now i have a good starting point, thanks for your help and the super fast reply.
Davy
2003 Kangoo Van
Reply
Tags
gear, kangoo, linkage, refitting, set
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
