Renault Master - Removing Lower Arms - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Wheels & tyres
Reply
Thread Tools Display Modes
Old 27th July 2009   #1
craiggasman
craiggasman is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi I have a Renault master V reg 1999 T28 2.5d I have a problem with my lower ball joint its U/S and I need to replace it however I have just spent all afternoon trying to remove the lower arm and I can’t see how you can remove it. Does anyone know how, can anyone tell me how to remove the lower arm I believe I will have to have the ball joint press in and out or do I just get a complete lower arm this is what I would have done with my old car there are no rivets holding it on to the arm
Many thanks
Craiggasman
Currently in craiggasman's garage:
Renault clio mk3
craiggasman is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by craiggasman
Renault Master - Removing Lower Arms Wheels & tyres craiggasman 2 12509 27th July 2009 07:13 PM
Sponsored Links
Advertisement
Old 30th July 2009   #2
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Hello and welcome to the forum.
The lower arms are a b4stard to remove and the joints are even worse to replace!.The arm is held by a long pin that runs the length of the arm,you need to remove the large nut from the front of the bar (30 or 32mm from memory) and then you can undo the bolts at the very back of the arm holding on a box type unit.Once this removed,you can then pull the pin out and the arm will come loose.
I changed a couple of these the other day and the joint was bl00dy tight to remove and press in,it would probably be an idea to remove the arm yourself and then take it to a garage or engineering workshop to have the old joint removed and the new one fitted.
Any problems with getting the arm off and I'll take some pictures of the ones we have at work and try and explain it a little better.
EDIT;Oh,and just to cheer you up,the upper arms are even worse!.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 31st July 2009   #3
craiggasman
craiggasman is
has no status.
Junior Member
Threadstarter
Many thanks for your reply. There is no nut in the box section just a what looks like a washer! I have tried knocking the bar through but no joy also the wishbone is not dropping to the floor after I have taken the joint off
Any more help would be grateful received
Many thanks
Craig
Renault clio mk3
Reply
Tags
arms, lower, master, removing, renault, t28
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
