Renault Master - Glow Plug Light On - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 29th July 2009   #1
168brad
168brad is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Renault master 51 reg glow plug light comes on as usual 5 secs or so, goes out then comes back on and stays on.
ive renewed all the plugs (3 of the 4 us) but light still keeps coming on, ive tested the feed to all the plugs and all seems normal. other than removing the bulb has anyone any ideas?
168brad is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by 168brad
Renault Master 2.5 g9u engine 2007 Engines 168brad 2 439 16th May 2015 10:44 AM
which one is 2007 master fuel pump relay Electronics 168brad 0 835 27th November 2012 09:10 AM
2004 3.0 140 dci Engines 168brad 2 2290 13th February 2010 07:00 PM
Renault Master - Glow Plug Light On Engines 168brad 3 6389 29th July 2009 07:16 PM
Sponsored Links
Advertisement
Old 29th July 2009   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
The glow-plug light usually doubles as an injection fault warning light so it may not be a glow-plug problem. Also have you tested for how long voltage is going to the glow-plugs - it shouldn't be constant.
What is the exact engine type??
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 29th July 2009   #3
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
The glow plug light also doubles up as the engine management light so the ECU is picking up on a problem with the system on your van.Ideally you'll need to get the ECU fault codes read at a decent independant garage with the right equipment and this should point you in the right direction.There are a number of common faults that can cause your problem,but without the codes you'll be playing an expensive guessing game.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 29th July 2009   #4
168brad
168brad is
has no status.
Junior Member
Threadstarter
Hi thanks that may be helpfull.
its a 2.2 g9u unit they are not on constantly. voltage comes on with ign goes off after 5 secs or so voltage comes back on when engine starts as usual for about 10 secs then voltage is cut but glow plug light is on
Reply
Tags
glow, light, master, plug, problem, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
