How to Service a Renault Kangoo Diesel? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 16th October 2009   #1
chandelirious
chandelirious is
has no status.
Member
chandelirious's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Alrighty There People!
I'm planning on doing a service on my Renault Kangoo next weekend - scary stuff - I've never done a service before but I feel that I should man up and do it myself.
So. I know that I need to change the oil, that I need to change the air filter.
What else do I need to do?
Is there a fuel filter that I need to change too?
What would you do? Talk me through it from the start - what tools I need, what materials I need, how long it will take a novice like me to do it!
Thanks in advance!
Currently in chandelirious's garage:
Renault Kangoo Van, 98 plate; Vauxhall Corsa, 07 plate
chandelirious is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by chandelirious
Kangoo Van Won't Start... Engines chandelirious 0 4983 31st January 2011 08:03 AM
Advice Wanted: Servicing my Kangoo Van Engines Hammer-ter 6 7533 9th September 2010 10:56 AM
Creating a mobile workshop in the Kangoo van... Interiors qwakers 6 4137 6th May 2010 01:39 PM
Renault Kangoo Van: Not Starting Engines chandelirious 23 7161 4th December 2009 02:11 PM
Sponsored Links
Advertisement
Old 27th November 2009   #2
gtemick
gtemick is
has no status.
Junior Member
Re: How to Service a Renault Kangoo Diesel?
Go out and get yourself a gallon of 10w40 and a full set of filters - oil, air and fuel.
Take the van for a good spin to get the oil warmed up then drive it over a pit or whatever means you have of getting the van up of the ground.
Screw out the bung and have a bucket or driptray which will hold more than 5 litres.
While waiting for this to drain and let it drain completely, change the air filter and fuel filter.
Air filter box is fitted with clips so you wont need any tools - its not rocket science.
Fuel filter you will need pliers or a 3/8 socket set to loosen the clips or possibly even a screwdriver as it depends on the clips whether they are factory fitted or have been changed. Make sure to fill the fuel filter with diesel to the top before refitting because you will airlock the system if you dont so THIS IS VERY IMPORTANT!!! :loser:
By this time your oil will have drained so refit the sump bung and screw out the oil fiter for which you need a filter wrench or chain.
When you replaced the oil filter you can start to fill the oil into the top of the engine and keep and eye on your levels by checking the dipstick 3/4 times so you wil need a clean rag. Make sure it mid way between min and max levels.
Once you have done all these checks put on the oil cap and you are ready to start your engine.
As a beginner this should take you no more than 1 1/2 hours.
Mickey
gtemick is offline   Reply With Quote Quick reply to this message
Old 27th November 2009   #3
chandelirious
chandelirious is
has no status.
Member
Threadstarter
Brilliant, thanks for your help, hopefully going to be doing this in a weekend or two.
So, as someone with no previous experience, what tools do you recommend that I use?
Reply
Tags
diesel, kangoo, renault, service
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
