AD4/DPO Autotransmission solenoids compatibility and more - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Transmissions
Notices
Transmissions Transmissions...
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Transmissions
Reply
Thread Tools Display Modes
Old 20th October 2009   #1
Tinkerman
Tinkerman is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hello All,
I have a megane 1997, K7M motor, AD4 A/T.
It has been acting up lately with several weird symptoms, eventually traced down to an intermittent A/T control solenoid (Electro-pilots as they're named by Renault), from now on I'll call them gear selecting solenoids (GSS).
The problem is that this solenoid comes as part of a harness including 4 GSS's, 1 pressure modulating valve (PMV), and a temp sensor, all amounting to big $$$$$ (to be specific, over 1000 including work...).
To avoid the hefty cost my gear specialist installed a GSS from a DPO A/T (also called AL4 in Peugeot-Citroen). They look physically the same, but the DPO solenoids can be bought in single units much cheaper (1/16 the cost!) and soldered into the old harness (the DPO harness is modular and has connectors for each, as opposed to AD4 which is one-piece).
I've measured and compared resistance readings of both GSS's (DPO snd AD4) and they seem very similar also electrically (30ohms AD4 vs 40ohms DPO), and moreover, the new DPO solenoid works just fine in my AD4. On the other hand, I've read in various places that not all solenoids from both A/T systems are compatible, e.g. the PMV's are not, because they are designed for different pulse widths. I've even found that even **within the DPO line** there was a change of pressure modulating valves during production life, that requires ECU reprogramming for the newer units if installed. *copy righted material removed
Analysing the doc, it seems that they're talking about two PSV's (one for A/T system pressure control and the other for torque converted locking mechanism not present in AD4) and not the gear selecting ones. As far as I could understand, the PRV's are pulse-width-modulated by the A/T ECU at high speed to to regulate the required A/T pressure based on the external pressure sensor output, hence must act very fast. On the other hand, the GSS's change only at gear shifts and are otherwise static.
Has anyone tried and can confirm that DPO GSS's are indeed compatible with AD4 in the long run?
Click image for larger version
Name:	DPO SHIFT SOLENOID.jpg
ID:	8509   Click image for larger version
Name:	DPO PWM SOLENOID.jpg
Tinkerman is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Tinkerman
2003 clio2 1.2L sequential (robotic) gearbox... Transmissions Tinkerman 0 909 20th June 2013 09:42 AM
Differences between Renault CAN CLIP s/w versions Tools & equipment Tinkerman 0 1055 12th December 2012 07:22 AM
weird Renault CAN clip diagnostic trouble code Tools & equipment Ice Barrell 2 3098 12th December 2012 07:14 AM
Reading 1997 Megane A/T diagnostic codes WITHOUT... Tools & equipment Tinkerman 13 10161 20th October 2012 11:53 AM
Why are those damn A/T solenoids burning up??? Transmissions Tinkerman 1 1374 10th October 2012 10:11 AM
Sponsored Links
Advertisement
Old 20th October 2009   #2
Tinkerman
Tinkerman is
has no status.
Member
Threadstarter
LOL, I see that I have used three different acronyms for the same thing...
PMV = Pressure modulating valve
PSV = Pressure stabilizing valve
PRV = Pressure regulating valve
They actually all mean the same thing...see pic named "DPO PWM SOLENOID".
And to our dear moderator: I've included in my above post a link to a pdf doc on a commercial website with the DPO/AL4 blowout of parts pictures and names, with the relevant comment about the compatibility issue and necessity of ECU programming, as well as attached the doc to my post. Both were deleted from the post. I now understand that attaching a commercial doc might constitute a copyright issue, but are links to external websites also prohibited here? Can I at least quote the remark about the compatibility issue?
Thanks.
Old 20th October 2009   #3
Pat.w
Pat.w is
has no status.
Edit
Posts: n/a
You should be OK to partially quote and link the site as it's in context of the thread
If we have a big issue, we'll take it out.
Thanks for asking
Old 20th October 2009   #4
Tinkerman
Tinkerman is
has no status.
Member
Threadstarter
Thanks for asking
OK, here goes...:
http://www.automaticchoice.com/Catalogue/dp0.pdf
notice the big red remark at the end of the doc (I tried but the doc doesn't allow copy and paste...so I'll attach a screen capture).
We're talking about the EPC and Lockup solenoids (parts 700G and 701G respectively). The GSS's are parts 702G.
also, note the AD4 blowout here:
http://www.automaticchoice.com/Catalogue/ad4.pdf
here we're talking about part 703G (solenoid set).
I'll attach a pic of that too here. Each solenoid in the pack is permanently attached to heat resistant (teflon coated?) wires and soldered to the sealed connector exiting the A/T case.
Name:	DPO solenoid compatibility issue.jpg
ID:	8512   Click image for larger version
Name:	AD4 SOLENOID PACK.jpg
Reply
Tags
ad4 dpo al4 solenoids, ad4 or dpo, autotransmission, compatibility, solenoids
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
