Kangoo Express 1.4 timing belt/waterpump job - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 6th November 2009   #1
Rolfe
Rolfe is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi guys, what a wonderful relevation this forum was when I stubmled across it earlier this evening.
I have a Kangoo 1.4 which now leaks coolant in the timing belt area. As I have heard the pump make some whining noise when starting up only to quiet down after 5-20 seconds I have more or less been waiting for it to happen.
I called different garages today including the local Renault dealer/garage. The "cheapest" wanted £900 to replace the pump and install a new timing belt kit, and the Renault garage was even worse. The price included parts and they calculated 6.5 hours for the job. Is it really that time consuming to replace the waterpump and timing belt on a Kangoo (more model information below). Do they have to take the engine out or loosen it from its mounts to swing it sideways to work on it? Taking a look today the workspace might best be described as "cramped" I think
I ended up ordering a waterpump, timing belt kit and "fan belt" kit. I have done some work on engines before but never on the Kangoo or any Renault. Are there any special pitfalls to look out for on this model?
Is the cooling system self-venting? If not, where can I find the venting?
Model information on my Kangoo:
RENAULT KANGOO EXPRESS VF1FC0BAF
Chassis # VF1FC0BAF25238171
Engine code: K7JA7
Paperwork says it is a 2002 model, but it is registered first time 2001.august.06
It is a 5 speed 1.4 petrol engine without AC.
It has 160.000km on it now so the cost of having a garage do this job is almost as much as the worth of the car. I figure if I replace the pump and timing belt I'll get 5 years/100.000km more out of it.
Last piece of information: I live in Norway and things are pretty expensive here so doing as much as possible yourself is a real money saver. Number of garages are limited and distances are long.
Any help or hints greatly appreciated. Have not found a Haynes book or any online photo-documentaries on the water pump/timing belt process on this engine.
Currently in Rolfe's garage:
Kangoo Express
Rolfe is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Rolfe
Kangoo 1.4i Drive axles and front bushings Engines Rolfe 1 1232 7th May 2010 09:32 PM
Front bearings DIY Kangoo 1.4i Wheels & tyres Rolfe 5 3196 4th February 2010 08:41 AM
Kangoo Express 1.4 timing belt/waterpump job Engines Rolfe 8 7695 6th November 2009 08:26 PM
Sponsored Links
Advertisement
Old 14th November 2009   #2
Rolfe
Rolfe is
has no status.
Junior Member
Threadstarter
Oh well..
Just waiting for the CRC to do its stuff.. Bolt holding v-belt pulley is really tight. Might the bolt holding the v-belt pulley have "left" threads?
Kangoo Express
Old 14th November 2009   #3
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Hello Rolfe,welcome to the forum.
The pulley bolt is definately not a left hand thread,they are just very tight and usually have thread lock on them too.
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 14th November 2009   #4
Rolfe
Rolfe is
has no status.
Junior Member
Threadstarter
Hey thanks
Hey, thanks for that piece of information. I was hanging on a 80cm long socket wrench with no luck so I was beginning to wonder.. I'll wait some more to give the CRC time before I go back with renewed vigor.
Kangoo Express
Old 14th November 2009   #5
Rolfe
Rolfe is
has no status.
Junior Member
Threadstarter
Tip of the day, think not..
A friend just gave me a tip. Put a big socket wrench on the bolt and support the wrench to the torpedo wall or a solid load carrying part. Give the starter a kick and presto..
I think not!
Kangoo Express
Reply
Tags
belt or waterpump, express, job, kangoo, timing
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
