Clio front brake caliper bolts - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Wheels & tyres
Reply
Thread Tools Display Modes
Old 13th November 2009   #1
Element
Element is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I recently tried to change the brake pads and discs on my wife's clio... ordered the parts and carried on for a relatively simple job... However all came to a big stop when I found the caliper 'top plate' retainer bolts had a weird form... Not Torx, not standard hexagonal heads but they have an internal five sided (pentagonal) drive??? I have never seen a five sided drive bolt in over 25 yrs working on cars! I tried everywhere for them and nobody seems to know about them. Imagine an Allen Key slot about the 9mm size but not with 6 sides but only 5!
Does anyone know what the tool for these is called and better still - where I can buy one from?
many thanks
E.
Currently in Element's garage:
Clio Mk 1, 1.2
Element is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Element
Clio front brake caliper bolts Wheels & tyres Lagdti 4 6751 13th November 2009 01:28 PM
Сlio Mk 1 Track rod inner balljoint dissembly Wheels & tyres 7 2575 4th November 2009 07:28 PM
Clio losing power Engines Element 5 2154 28th March 2009 10:23 AM
Old Clio Economy Engines madnoel10 8 1376 13th December 2008 09:01 PM
Freezing Clio Accelerator Cable? Engines Element 4 2055 3rd December 2008 10:41 PM
Sponsored Links
Advertisement
Old 13th November 2009   #2
tolsen
tolsen is
has no status.
Banned User
Nominated 0 Times in 9 Posts
Nominated TOTW/F/M Award(s): 3
You don't need to remove the top pentagonal allen bolt. Just remove bottom bolt and swing the caliper out.
Currently in tolsen's garage:
Trekka 1.9 DCI, Smart Cabrio Cdi (65 - 85 MPG) & Ford Transit 2.2 Duratorq TDCi
tolsen is offline   Reply With Quote Quick reply to this message
Old 13th November 2009   #3
Element
Element is
has no status.
Junior Member
Threadstarter
I just found out that there's another two bolts that I could undo to perhaps get access to the pads rather than these pentagonal ones; so maybe all is well after all... will have a go tomorrow...
E.
Clio Mk 1, 1.2
Old 13th November 2009   #4
tolsen
tolsen is
has no status.
Banned User
Yes, you can also undo the two larger bolts that hold the caliper to the hub. Easier just removing the lower bolt and swing caliper out. Alternatively, buy a special pentagonal bit for Girling brakes.
Old 16th November 2009   #5
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
The bolts have five sided heads for a reason,i.e they don't need to be undone unless someone is repairing/reconditioning the caliper it's self.
I'm sure you'll find that the pads are held in place by a slide which in turn is held in with a horse-shoe or R-clip.You take the clip out,tap the slide out and then remove the pads.Take particular notice to the shape of the pads and which side they come from,it's very easy to fit them incorrectly and then have problems refitting the slide.There should also be some anti-rattle springs on the pads which are often missing or fitted incorrectly.You need to push the pad against the spring to be able to refit the slide,it can be fiddly if you haven't done them before but hopefully all will become clear once you get into the job.
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Reply
Tags
bolts, brake, caliper, clio
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
