Auxiliary belt tensioner - 2001 Scenic 1.9dci - Page 2 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 23rd November 2009   #6
tolsen
tolsen is
has no status.
Banned User
Nominated 0 Times in 9 Posts
Nominated TOTW/F/M Award(s): 3
Perhaps a pulley is not perfectly round or its grooves are filled with dirt or something. That would explain why tensioner pulley keeps vibrating. A mechanics Stethoscope would come handy if the problem is bearing noise, but based on your description my guess is one of the pulleys is no longer round.
Currently in tolsen's garage:
Trekka 1.9 DCI, Smart Cabrio Cdi (65 - 85 MPG) & Ford Transit 2.2 Duratorq TDCi
tolsen is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 23rd November 2009   #7
dav214
dav214 is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Cool aux belt pulley noise
Check your alternator pulley im on my second
Currently in dav214's garage:
renault scenic 1.9dci privelage
dav214 is offline   Reply With Quote Quick reply to this message
Old 23rd November 2009   #8
tolsen
tolsen is
has no status.
Banned User
Quote:
That alternator pulley is not cheap. It was fubared on my Kangoo. Went to Renault to buy a new pulley but left empty handed. Cost was 70 pounds for a small plastic pulley! Took the existing pulley off and turned it true on my lathe.
Old 23rd November 2009   #9
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
I strongly suspect that the pulley on this posters car has a clutch inside of it which has seized,this causes the belt tensioner to jump around on idle making a nasty vibration noise.To test,remove the belt and grab the alternator pulley,spin it with your hand clockwise and then abruptly hold it to stop it.You should feel the alternator internals run on for a fraction of a second with the pulley held still.If it doesn't then the pulley is fubar'd and it needs replacing asap as they can fail and cause allsorts of expensive damage,especially if the aux belt gets wrapped around the crank pulley and goes into the cambelt.
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 24th November 2009   #10
tolsen
tolsen is
has no status.
Banned User
Quote:
I assume that Lagdti is refering to some kind of freewheel or decoupling pulley. Renewing that with a standard solid pulley is going to be more reliable.
Reply
Tags
19dci, aux, auxiliary, belt, scenic, tensioner
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
