Steering Clunk - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Steering and Suspension
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Steering Clunk
Reply
Thread Tools Display Modes
Old 24th November 2009   #1
rf065
rf065 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Steering Clunk
I have a 2002 Kangoo and when turning on full lock at slow speeds there is a clunk noise. If I turn the wheel in the opposite direction and move slowly it clunks again.
It does not make this noise when moving at normal speeds, although hitting the brakes at 60mph will make the steering wheel twitch and the car feels as if the front wheels want to turn and not go straight, but only during the second that the brakes are first pressed and the front suspension compresses, after that it brakes perfectly straight and feels OK.
I have had the garage look at this a few times now, the brakes have been renewed and are working correctly, they are not the cause of the clunk or the steering twitch.
Any ideas, the garage have given up?
Russ
Currently in rf065's garage:
Mercedes CLK
rf065 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by rf065
Steering Clunk Steering and Suspension rf065 10 3010 24th November 2009 08:24 PM
Sponsored Links
Advertisement
Old 25th November 2009   #2
mord
mord is
not a complete idiot, some parts got Leftbehind,...(in the UKraine)
Platinum member
mord's Avatar
Nominated 2 Times in 10 Posts
Nominated TOTW/F/M Award(s): 3
if the track rod ends and track rod arms have been checked as ok, it could be:
the thrust bearings in the top of the shocks
the lower arm (inc ball joint)
anti-roll bar linkages (sorry im not familier with kangoo layout for antiroll bar setup)
have they also checked the lower arm bolts/subframe bolts???
I had a occasional clunking issue with my laggy2 after they replaced the front lower arms(during a major suspension renewal.)
Although they tightened the bolts up to the right torque (didn't replace them though!) they were just lose enough (from being over stretched already) to allow slight movement (when under full load of the car on the road, as opposed to being suspended on a 2 post ramp) of the lower arms when turning lock at slow speed.
they had another two goes at really getting them tightened and the problem went away.
so it pays to replace the bolts when renewing main suspension parts.
Currently in mord's garage:
The CreditCard Holes sooo DEEEEP NASA have put up warning signs about a black hole on the Driveway: update, the driveway and home have fallen in...
mord is offline   Reply With Quote Quick reply to this message
Old 25th November 2009   #3
rf065
rf065 is
has no status.
Junior Member
Threadstarter
When the clunk occurs, I can feel as if something has moved on the front left hand suspension, if turn the wheel on full opposite lock, it will clunk again as if it is moving back into it's original position. This only occurs at walking speed on full or nearly full lock.
The garage claim to have checked everything, but although they cannot find the fault did admit that it can be felt when braking from m/way speeds.
Russ
Mercedes CLK
Old 25th November 2009   #4
mord
mord is
Platinum member
mord's Avatar
its lower arm or subframe bolts!
get them checked over, tightened up more or replaced.
get them to tighten them up with the car on a roll-on-roll off ramp (4 poster ramp, not the 2 post one with arms) the sub frame wont sit correctly unless its got the cars full weight on it when tightened up.
it will be a PITA for them as there wont be much room between the ramp and the car to work in and it will take 2 grease monkeys under there to get it tightened up properly as the tops of the bolts are hard to reach.
Old 25th November 2009   #5
pragmatix
pragmatix is
Folding again
Platinum member
pragmatix's Avatar
Ive had a similair problem and it turned out to be lower wishbone mounts, not sure about the Kangoo but would suspect the set up will be similair. Try another garage or get a friend to turn the steering wheel while you look and feel round the suspension
__________________
The older I get the better I was, must be mad not got enough money to be excentric
Currently in pragmatix's garage:
Ford Mondeo Ghia X estate, Skoda Roomster 1.6 Alfa Mito1.4 veloce,Cervelo S2, Gaint Defy Advanced e
pragmatix is offline   Reply With Quote Quick reply to this message
Reply
Tags
clunk, steering
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
