Megane faulty indicators 1.6RT - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 6th December 2009   #1
MONKEYSPANNER
MONKEYSPANNER is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Can anyone help. I have a 97 megane 1.6 RT, the indicators are becoming faulty. Sometimes the left side will not work, more often the right side will not work. I can get them starting by a quick flick of the drivers door window switch ! but I want to correct it.
I know the steering wheel pivot can damage the cable but is not that and the indicator stalk is ok.
I would like to try a second hand fusebox of the correct part number.
A) Is the fuse box controlled by the key ?
B) Is the ECU controlled by the key ?
C) Is the interior sensor controlled by the key ?
D) If I change the fuse box will I need it`s original key
E) I was told that the fuse box can only be factory programmed once, is this true ?
F) If I change the fusebox because I believe it has a
relay fault, do I also need the ECU, interior sensor and key & locks off the donor car.
Sorry for the technical questions but I hope
someone can help.
Monkey Spanner
Currently in MONKEYSPANNER's garage:
1997 RENAULT MEGANE 1.6 RT
MONKEYSPANNER is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by MONKEYSPANNER
Fuse box part numbers Electronics mord 1 1219 20th January 2010 09:10 PM
Ecu fusebox & keys - compatability Electronics Prestige_Decodes 1 1277 9th January 2010 09:03 PM
Megane faulty indicators 1.6RT Electronics MONKEYSPANNER 5 1722 6th December 2009 05:15 PM
Sponsored Links
Advertisement
Old 6th December 2009   #2
cph1984
cph1984 is
has no status.
Diamond member
cph1984's Avatar
Nominated 0 Times in 1 Post
Re: Megane faulty indicators 1.6RT
Hi and welcome to the forums
I've never come across this problem before.
However if you think it's a relay fault would it not be easier, faster and cheaper to replace all the relays in the fusebox?
If you feel you want to change your fusebox you will need everything you listed above except for the interior central locking sensor and the locks. You will however need the plip(key head) off the donar vehicle
The sensor is not coded to the car its just plug and play;
and the key you have has a removable blade so you can keep your origional locks and just swap your blade into the donar plip head.
I'm not 100% sure if the fuse box is even coded to the vehicle in the scenic 1 as the ECU stores the immobiliser info.
Someone will clarify this soon I'm sure.
Hope that helps
Currently in cph1984's garage:
2001 VW Golf TDi
cph1984 is offline   Reply With Quote Quick reply to this message
Old 6th December 2009   #3
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Have you checked out the hazard warning light switch - a known weak point on Renaults.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 9th December 2009   #4
MONKEYSPANNER
MONKEYSPANNER is
has no status.
Junior Member
Threadstarter
Hope that helps
CPH1984 & Madnoel 10,
Thankyou for the replies. I first considered replacing the relays but the external ones are soldered in, the
other relays are inside the fusebox ! and opening the box may cause further damage.
I have replaced the hazard light switch with a second hand one, it did`nt improve the problem.
What I may do next is to take a chance on a replacement fuse box of the exact number/model as
I`m not absolutely sure if it`s coded. If it dose`nt
work, I`ll strip it down and unsolder the relays and tranplant them into the original box. Although if I get it wrong the Megane could be life less. I may carry on just flicking the drivers door switch.
Monkey spanner.
Old 9th December 2009   #5
Gogslad
Gogslad is
has no status.
Diamond member
Gogslad's Avatar
Have a look at the fuse box beside the battery and check the maxi fuse holders for corrosion, will cause a drop in current to the fuse and relay box inside the car which will cause all sorts of bizarre electrical issues.
__________________
Currently in Gogslad's garage:
Koleos, RR1 Fireblade, RRW Fireblade, CZ 125.
Gogslad is offline   Reply With Quote Quick reply to this message
Reply
Tags
16rt, faulty, indicators, megane
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
