Grand Scenic 08 - Location of Fuel Drain Plug - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 14th December 2009   #1
banner257
banner257 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I am told that there is no fuel drain plug fitted to my 2008 grand scenic diesel, can anyone help on how to drain the fuel tank?
Currently in banner257's garage:
2008 Grand Scenic
banner257 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by banner257
Grand Scenic 08 - Location of Fuel Drain Plug Engines banner257 3 4159 14th December 2009 04:16 PM
Contaminated Fuel! Engines banner257 3 1547 15th September 2009 02:30 PM
Sponsored Links
Advertisement
Old 14th December 2009   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Grand Scenic 08 - Location of Fuel Drain Plug
Very few modern cars have drain plugs on the fuel tanks otherwise fuel theft would be just so easy.
It may be possible to syphon most of the fuel via the filler neck. Some garages and breakdown services have a special pump for the job. Otherwise it may entail removing the fuel tank sender unit for access and a looksee inside.
In modern cars the only sure means of cleaning the tank is to remove the tank and have it professionally flushed.
Why do you need to empty the tank anyway??
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 14th December 2009   #3
cph1984
cph1984 is
has no status.
Diamond member
cph1984's Avatar
Nominated 0 Times in 1 Post
The fuel pipes run up the drivers side of the car. There are two unions just below the drivers seat on the underside of the car. If you disconnect the pipes there the fuel will run out.
Petrol in a diesel perhaps? If so be sure to change the fuel filter too
Currently in cph1984's garage:
2001 VW Golf TDi
cph1984 is offline   Reply With Quote Quick reply to this message
Old 14th December 2009   #4
banner257
banner257 is
has no status.
Junior Member
Threadstarter
Thanks for that, the contamination is alge and other growths. This seems to be a more common problem today due to the bio-diesel being mixed with traditional diesel.
2008 Grand Scenic
Reply
Tags
drain, fuel, grand, location, plug, scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
