Steering Column part number help - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Wheels & tyres
Reply
Thread Tools Display Modes
Old 21st December 2009   #1
matty_doodle
matty_doodle is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question Steering Column part number help
Hi Guys,
1st post here so cut me a bit of slack if needed.
I have a problem with my 54 plate Renault Scenic. 1.6 petrol Dynamic. It seems that the steering column has failed and I’ve been told by Renault that this is going to cost £1,403 to fix!!!!
I have got a reliable garage that can fit me a part from a breakers yard. If I can locate one
The part number off my steering column is 8200 035 273 then it seems to have the code ITG after it.
I have been contacted (via find a part) by a few breakers yard having in stock the part I need off a very similar model. The trouble is the part number is different. All of them start with 8200, but then have different codes after then e.g. 8200 246 633.
I don’t want to order the part and find I have gotten something that won’t fit or work. Could anyone advise what the actual part number is I need?
Car details are:
  • RENAULT
  • SCENIC DYNAMIQUE 16V
  • 1598
  • 5 Speed Manual
  • Petrol
  • Year 2005
Many thanks all
Matt
matty_doodle is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by matty_doodle
Steering Column part number help Wheels & tyres mord 1 1104 21st December 2009 05:45 PM
Sponsored Links
Advertisement
Old 21st December 2009   #2
mord
mord is
not a complete idiot, some parts got Leftbehind,...(in the UKraine)
Platinum member
mord's Avatar
Nominated 2 Times in 10 Posts
Nominated TOTW/F/M Award(s): 3
Re: Steering Column part number help
the part alone (8200035273) is about £931 net price and usual price to fit a steering rack with dealerships is around £250 for a full dashboard stripout.
so a quote for £1400 is about right
do you know what has failed on the rack ?
btw that second part no. is £1031
what is the 1st 4 digits of the VIN ? as anyone checking will need the chassis version??? (JM##) ?
If the fault is electronic on the steering column, then unless the fault in the (electronic lock sub-module) is due to a mechanical sub compnent in it, then you will have to get a new column.
If its only mechanical then you may be able to getaway with just changing the mechanism and swapping the electronic module over. (the electronics module is pre-coded to the car and not interchangable)
I'm not familier with this part so have no idea if you could save money swapping sub components of the unit.the electronics module may have different mounting fittings.
if the weather wasnt so horrible out there, i might run round all the local yards and see if i can help find a matching part.
Currently in mord's garage:
The CreditCard Holes sooo DEEEEP NASA have put up warning signs about a black hole on the Driveway: update, the driveway and home have fallen in...
mord is offline   Reply With Quote Quick reply to this message
Reply
Tags
column, number, steering
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
