I am in need of the head bolt torque settings for a renault clio, 1.2, mk 2 1998 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 29th December 2009   #1
Rushy-clio-
Rushy-clio- is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi please can anyone help me locate the settings needed for the head bolt torque settings? anyhelp much appreciated!! Thanks Tom
Rushy-clio- is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Rushy-clio-
Key reprogramming Electronics Gogslad 2 1682 3rd January 2010 06:38 PM
I am in need of the head bolt torque settings for... Engines Ivorbiggan 5 15672 29th December 2009 01:16 PM
Interference engine or Non-Interferance engine? Engines clio_99_laguna_00 7 7029 17th November 2009 07:44 PM
Breaks sticking on?!!! Wheels & tyres Ralph 3 1167 25th July 2009 07:20 PM
Sponsored Links
Advertisement
Old 29th December 2009   #2
knownClone
knownClone is
a bit stinkkie...
HotShoe WANNABEE..
knownClone's Avatar
Nominated 0 Times in 1 Post
Thumbs up Re: I am in need of the head bolt torque settings for a renault clio, 1.2, mk 2 1998
16V
...All cylinder head bolts must always be changed
after removal.
Do not oil the new bolts.
Tightening torques are expressed in decaNewton
metres (daNm)
Reminder: 1 daNm = 1.02 m.kg.
>>> Bloo*y French!
Tighten all the bolts to 2 daNm±0.2 daNm.
Check that all the bolts are tightened to 2 daNm, then
angle tighten (bolt by bolt) by 230***730;±6***730;.
Do not retighten the cylinder head bolts after
performing this procedure.
The pattern for this is spiraling out from Middle bolt (1). over Exhaust Mani, to (10) over Inlet Mani - furthest from cambelt.
:loser:
knownClone
Currently in knownClone's garage:
Proton Savvy + [Worx] PugPartner
knownClone is offline   Reply With Quote Quick reply to this message
Old 29th December 2009   #3
Rushy-clio-
Rushy-clio- is
has no status.
Junior Member
Threadstarter
Sorry I failed to mention it was an 8v. Cheers
Old 29th December 2009   #4
knownClone
knownClone is
a bit stinkkie...
HotShoe WANNABEE..
knownClone's Avatar
Talking Re: I am in need of the head bolt torque settings for a renault clio, 1.2, mk 2 1998
.. no probbs.... there'll be a 16V along in a minute..lol
:loser:
knownClone
Old 29th December 2009   #5
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
1.2 8 valve is as follows....
Tighten bolts in order....
8 4 1 5 9
7 3 2 6 10 (engine flywheel this side).
First stage is 20Nm
Second Stage is 90 degrees.
Wait 3 minutes (I don't you need to be too accurate with the time,a few minutes or time to have a cup of tea would do.).
Then slacken off bolts 1 and 2,tighten to 20Nm then 200 degrees.
Repeat with bolts 3,4,5,6 and then 7,8,9,10.
Job done.
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
The Following 2 Users Say Thank You to Lagdti For This Useful Post:
dutchman376 (20th December 2011), makka (13th December 2011)
Reply
Tags
bolt, clio, head, renault, settings, torque
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
