Headlight replacement on 51 palte Clio - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Bodywork
Notices
Bodywork Paint care, corrossion, body kits, spoilers, skirts etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Bodywork
Reply
Thread Tools Display Modes
Old 5th January 2010   #1
andynd69
andynd69 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
HELLLLPPPPPPPP!!!
I am having a mare trying to replace the drivers side head light on my Clio 51 plate, the issue is there is a large pipe from the aircon right behind the bulb. Got the cover off and managed to the old bulb out but cannot get the new one in and cut my hands to bits.Help please
Cheers
Andy
andynd69 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by andynd69
Headlight replacement on 51 palte Clio Bodywork blimeyoriley 3 4527 5th January 2010 09:52 PM
Clio 51 plate external temperature gauge Electronics itdoban 2 1581 25th November 2009 01:50 PM
2001 Clio gear stick moving!! Engines madnoel10 5 1850 28th July 2009 12:27 PM
Sponsored Links
Advertisement
Old 10th January 2010   #2
AlexClio
AlexClio is
has no status.
Junior Member
Re: Headlight replacement on 51 palte Clio
Hi Andy!
I am afraid that I do not have any advice to give but was wondering how you solved your headlight bulb replacement problem? I am having the exact same issue with my 2001 Clio and thought the replacement procedure looked easy enough to tackle until I saw the limited amount of space you have to do it!!!
Would be grateful for any advice you or anyone else can give.
Alex
Currently in AlexClio's garage:
2001 Renault Clio II 1.4 16v
AlexClio is offline   Reply With Quote Quick reply to this message
Old 10th January 2010   #3
ross1991
ross1991 is
has no status.
Junior Member
ross1991's Avatar
Hello guys,
I had the same problem a while ago, it's not an easy procedure!!! Took two of us to get it done, you've just got to try a variation of holding things out of the way and getting the other one to twist, whoever has the smallest hands would be best twisting whilst the other one holds.
Also, is there any corrosion on the inside of the headlight cluster? Me and two of my mates had this problem. If there is any sign of corrosion, it's usually the actual fitting which the new bulb goes in to in which case its a new headlight cluster.
Anyway, sorry I cant be of more help, good luck with it and let me know how it goes.
ross1991
Currently in ross1991's garage:
2001 Renault Clio 1.2 16v Dynamique
ross1991 is offline   Reply With Quote Quick reply to this message
Old 30th June 2012   #4
blimeyoriley
blimeyoriley is
has no status.
Junior Member
I have a 2004 Clio and had the same problem, think the aircon is in the way. A lot of people say remove the bumper but you don't have to!
It's a pig of a job, move the tubes that you can out of the way, then the dust cap. I used a set of pliers to help and it is a squeeze to get it out but is doable!
Remember it only needs turning slightly and it will pop out.
Good luck!
Currently in blimeyoriley's garage:
2004 Renault Clio 1.4 Dynamique
blimeyoriley is offline   Reply With Quote Quick reply to this message
Reply
Tags
clio, headlight, palte, replacement
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
