Renault Megane Alarm problem - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 9th January 2010   #1
M-Ster
M-Ster is
has no status.
Junior Member
Nominated 2 Times in 2 Posts
TOTW/F/M Award(s): 0
hi my partner has a renault megane(migrain) cabriolet 1.6 8v 1997
The battery died so i took it off and got a new one but i cannot refit the battery without the alarm having a fit.
It has an alarm immob unit with the sounder next to the battery not through the horn i connect the battery as soon as i do the alarm goes off try resttingit with the fob and it locks and unlocks the doors but keeps sounding if i get in the car start the engine the alarm sounds but goes off after bout 10 seconds switch it off and off it goes again try using fob still wont switch off the led is indicating that the immob is not switch off any ideas hows to reset or stop it going off
Currently in M-Ster's garage:
1997 Renault megane cabriolet 1.6 8v
M-Ster is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by M-Ster
Renault Megane Alarm problem Electronics rockbob 5 14968 9th January 2010 10:15 PM
Sponsored Links
Advertisement
Old 10th January 2010   #2
dogbot
dogbot is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
Re: Renault Megane Alarm problem
i have a 1.8 scenic with the same problem i use the dead lock botton on the dash that works some times and then the alarm kicks off so i dont lock it ive asked loads of alarm specialists but its got them stumped
Currently in dogbot's garage:
2001 renault scenic 1.8 16v privalige
dogbot is offline   Reply With Quote Quick reply to this message
Old 10th January 2010   #3
M-Ster
M-Ster is
has no status.
Junior Member
Threadstarter
Managed to disconnect the sounder so now just hazards keep flashing immob light stays on constant indicating immob fault
Old 10th January 2010   #4
pragmatix
pragmatix is
Folding again
Platinum member
pragmatix's Avatar
It could be that the key is not synchronised to the imobiliser, that happens on my Citroen sometimes, I reset it by locking and unlocking the doors 3 times with the key, you may have to do something similair, hope that helps
__________________
The older I get the better I was, must be mad not got enough money to be excentric
Currently in pragmatix's garage:
Ford Mondeo Ghia X estate, Skoda Roomster 1.6 Alfa Mito1.4 veloce,Cervelo S2, Gaint Defy Advanced e
pragmatix is offline   Reply With Quote Quick reply to this message
Old 10th January 2010   #5
M-Ster
M-Ster is
has no status.
Junior Member
Threadstarter
Ok have been out in the freezing cold again tried the other key fob and that wont work tried locking unlocking triple unlocking double triple single unlocking and still nothing i started checking through the fuses found if i romoved fuse 15 the immob would go off car would start fine and all tickateboo but in removing that fuse im not sure if its knocked out anything else tried looking on wiring diagram but cant find it on there and to make it even more difficult the numbers on the fuse box are completely different to the numbers in the work shop manual
The Following User Says Thank You to M-Ster For This Useful Post:
Chrisdobek666 (21st September 2014)
Reply
Tags
alarm, megane, problem, renault
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
