Renault Forums :: Independent Renault forum
Notices
Engines Engine/transmission and other oily matters
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
replaced camshaft sensor, coil pack, high tension ignition lead and still trouble
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 7th February 2010   #1
Maryclaire
Maryclaire is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question replaced camshaft sensor, coil pack, high tension ignition lead and still trouble
Hi everyone I'm new to this so please be gentle..my car ( renault megane '98 1.4 rt) started giving me trouble a few weeks ago...it wont start after lying idle overnight. the firsy time it broke down I called breakdown assist they said it could possibly be camshaft sensor, the mechanic i brought it to agreed the same so he replaced the sensor and bingo car was going again..next morning same problem it would not turn over, called the mechanic out again and he said replace coil pack so done that and replaced the high tension ignition lead as well after replacing these the car ran brilliantly...this morning tried to start it and again same problem it would n't turn over..my dad came over to have a look ..he pressed down the excelerator and the clutche pedal at the same time as turning the key in the ignition and after a few splutters and revs the bugger started up..i'm delighted that it is running today but uncertain about whether it will start tomorrow!! has anyone any suggestions as to what to try next? my heads wrecked buying parts..many thanks for any help..
Currently in Maryclaire's garage:
Renault Megane 1.4 rt
Maryclaire is offline   Reply With Quote
5 Lastest Threads by Maryclaire
replaced camshaft sensor, coil pack, high tension... Engines Maryclaire 5 363 7th February 2010 05:47 PM
Old 7th February 2010   #2
Maryclaire
Maryclaire is
has no status.
Junior Member
Threadstarter
Re: replaced camshaft sensor, coil pack, high tension ignition lead and still trouble
please anyone if I replaced inlet air temp sensor would this help? I could read the posts for ever and still not have a clue
Old 7th February 2010   #3
cockers
cockers is
has no status.
Diamond member
hi , from reading the posts the car does not turn over when the fault happens ?
if so get the starter motor solenid wire terminal relaced. or it may be the stater itself. your mechanic may have already checked this ?
cockers is offline   Reply With Quote
Old 7th February 2010   #4
Maryclaire
Maryclaire is
has no status.
Junior Member
Threadstarter
Hi cockers, thanks very much for replying to my post
sorry if i messed up in explaining clearly... the ignition is turning but does n't seem to make the connection to the sparkplug..hope I'm making sense if it were the starting motor would n't it just make a clicking noise? thanks for your time and patience
Old 7th February 2010   #5
Liam McGurk
Liam McGurk is
has no status.
Junior Member
Have you or your mechanic tried to clean the flywheel sensor situated on top of the gearbox. If not remove and clean you could also check the resistance should be approx 250 ohms. This also may help, have you changed the exhaust silencer? or checked to see if the baffles have failed or partially blocking.
Hope this helps you, Liam
Liam McGurk is offline   Reply With Quote
Reply
Tags
camshaft, coil, high, ignition, lead, pack, replaced, sensor, tension, trouble
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
