Hello, I am hoping someone can help me please. I am having a problem removing the rear brake bleed nipple. No matter what I try it will not move. Does anyone have any ideas why this is, also which way should it unscrew. Thank you.
Just a normal thread ACW to unscrew. They are easily sheared off, soak it with releasal/plus gas/WD40 give it a smart tap on the end with a hammer and be careful. If the worst happens you can always bleed the brake by loosening the brake pipe nipple, but that has other dangers
Currently in roby37's garage: 2005 Grand Scenic 1.5dCi
Thank you Roby37 for your reply. I did bleed with using the brake pipe nipple in the end. I see you say this would have other dangers, what would these be please?
