Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
ABS - replace ring sensor, CV joint or drive shaft?
Electronics
Reply
Thread Tools Search this Thread Display Modes
Old 9th February 2010   #1
jojooneill
jojooneill is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My ABS and service light appeared on my 53 Renault Clio 1.2 Extreme 16V so I went to my Renault Dealer. They put it through the Diagnostics machine and stated that two ABS (front) rings were cracked and needed replacing. They said the ABS rings are glued on to the drive shafts and hence both drive shafts needed replacing to fit the new rings. For this they would charge £565.18.
I have rang Halfords, Kwik Fit, local dealers etc and they have quoted me prices for ABS rings (£12.95 - to £41) CV joints (£36) and drive shafts (£350). I am rather confused now - is it possible just to replace the two front ABS rings without having to replace the CV joint/drive shafts?
Any help would be much appreciated.
Many thanks!
Currently in jojooneill's garage:
2004 Renault Clio 1.2 16V Extreme
jojooneill is offline   Reply With Quote
5 Lastest Threads by jojooneill
ABS - replace ring sensor, CV joint or drive... Electronics jojooneill 2 1139 9th February 2010 09:17 AM
Old 9th February 2010   #2
madnoel10
madnoel10 is
has no status.
Platinum member
Nominated TOTW/F/M Award(s): 4
Re: ABS - replace ring sensor, CV joint or drive shaft?
As far as I know the reluctor rings are a tap on fit using no adhesives.
Try the link below it may assist. It also gives some advice on fitting and repair or reluctor rings.
http://www.evilution.co.uk/index.php?id=453
Currently in madnoel10's garage:
1994 Clio diesel and a Honda Civic 1.4l
madnoel10 is offline   Reply With Quote
Old 9th February 2010   #3
jojooneill
jojooneill is
has no status.
Junior Member
Threadstarter
Many thanks for your help - I will buy two R.Rings and get them fitted. Hopefully this will make a difference!If not, I will have to go the drive shaft route.
Thankyou!
Reply
Tags
abs, drive, joint, replace, ring, sensor, shaft
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
